Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Hot tub pump stops and control panel says there is a flo problem
Either the pump is shutting itself down or the spa pack is shutting it down and indicating a flow problem. The motor is thermally protected and now I am suspicious that it is getting too hot and shutting down...then the spa pack indicates no flow. Or else the spa pack is shutting the pump down. I have jumpered across the pressure switch and it still shuts down. Does a thermally protected motor shut down to avoid getting damaged from too much heat? And what would cause the motor to get too hot. The pump is a 5 hp pump, but only the 1.5 hp product shows up on the list.
    Top Expert:
  • Aqua Flo Master
  • 8,163 Answers
The pump you are looking for is the recirculation pump
Posted on Mar 24, 2018
    Habit-Forming:
  • 77 Answers
Yes a pump does have a thermal cut out. When the motor gets too hot the thermal cut out will activate and the pump won't restart until the motor has cooled.
If you were an electrician, or highly confident/competent with electrics, you could test the motor with a volt meter. Run the spa and as soon as the pump stops running, check the voltage at the pump. If there is voltage at the pump, then the thermal cut out on the motor has activated. Do not try checking this yourself if you're not competent to do so.
You could also do the same test at the spa pack if it's easier to do so, just locate the output to the pump.
What spa and which spa pack have you got?
Cheers,
Ian.
Posted on Apr 28, 2017
4 Suggested Answers
  • 246 Answers
SOURCE: I have an appolo spa explorer model...bought it
you must have a small pump call laing if you do, air picket inside the plumbing try to turn both pump on high and wait few minutes if doesn fix try to loose the nut just a little bit with the breakers off and let the air go out. try one more time. if doesn work turn on high both pump and touch if they are working then a impeller may be broken inside one of them try to turn each one separate to find wich one as t he broken impeller.
Posted on Oct 29, 2009
macdirk
  • 116 Answers
SOURCE: Aqua flo master piump is
Thermal switch should not be causing the problem. It is much more likely that the problem is the motor, or shorted wiring. If there is a thermal overload switch it will be mounted inside the tail of the motor, but you may need to completely pull the motor apart to get to it. Is the breaker tripping only when you turn the pump on? what I mean is if the pump is off will the breaker reset, and then only trips when you try and turn on the pump? check wiring closely where it comes into the motor, and look for bad insulation where it might be touching the frame or another wire. If your familiar with motors and windings, you can also disconnect the wires from the motor and check the windings with an ohm meter. How old is the pump? and how long has it been installed. Is this a new problem on an old installation? or did you just install the a new motor? Also if you still suspect the motor, might be worth taking down to a pool pump repair shop if there's one near by most will test a motor for you for free. If you need more help, post a comment and'll I'll reply asap. Good Luck!
Posted on Sep 19, 2010
adamh294
  • 310 Answers
SOURCE: I was told that the Aqua Flo Master Xp2 Spa pump
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Posted on Jan 13, 2011
Testimonial: "Thank you so much. That helps alot. Do you have any other suggestions for a pump tha might be less expensive then a Max E Pro?"
Control panel and no pumps
do you have the control box cover off? some have a safety switch that will shut the tub down if the cover is removed..find this button and tape it down.. check the rest of the switches for proper operation..either from remote or on the unit..its a process of elimination thing.. I have been doing this for 4 days on our tub.. its finally heating now..only thing is the air blower is not working..
Jan 05, 2014 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
How do you reset an imperial hot tub flo control panel? this one is 10 yrs old.
shut it off entirely .. unplug..reconnect and power it back up reset all settings..
Nov 21, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Replacing flow sensor on reflections hot tub
check recirculation pump if ok pressure sensor mounted to metal tube with wires to board
Apr 11, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Beachcomber hot tub pump 2 wont shut off
Stop button on your control panel is malfunctioning or defective; not acting as a normally close (NC) contact again.
It has to be replaced.
Oct 12, 2017 | Pool & Spa
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
The flo, cool, and a temp of 53 but the heat indicator is not on?
Assuming that pump 1 works ok on low speed...
Try removing the filter(s) and see whether or not this clears the fault. If the fault has gone install some new filters.
Apr 15, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pump shuts itself off
Fill the tub with water, disconnect the supply pipe to the pump and ithe head of water should push out any air
Make sure you can get the hose back on easily before you fill the tub other wise you are going to get wet
Oct 09, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
797 people viewed this question
Top Aqua Flo Pool & Spa Experts
Jay Finke
Jay Finke
Gene Haynes
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
