Electric Demolition Jackhammer Logo
A
Anonymous Posted on Jun 30, 2014
How do I find Instruction manual for Hitachi 1700w electric Jack Hammer
Pieter Vleeshouwers
Level 3:
  • Electric Master 2,029 Answers
  • Posted on Mar 26, 2016
Pieter Vleeshouwers
Electric Master
Level 3:
Answers
2029
Questions
0
Helped
4113598
Points
7389
Service Support or google for hitachi hammer and under the choice of images you have chance .
Jack hammer makita hm1304 lubricant used
Makita A-90582 or (the equivalent)
Hitachi 981840 Hammer Grease
But dont forget to replace all o-rings and seals at the same time some older models have special wear tear parts sets for service also called maintenance spare parts. If the brushes are short then its time for service.
My electric jack hammer 1700W stopped and now nothing happens when i depress the trigger. What can i do ?
Check the brushes first, they're the easiest and most likely cause of your problems. New tools are being equipped with brushes that have non-conductive pins in them that pop out when the brushes wear down so the armature doesn't get damaged. Next, do continuity checks to see if power is geting to and through the switch. Many cords get internal breaks at or near the boot where they go into the tool from frequent bending or at he plug end from being unplugged by pulling on the cord and not he end peice. If the cord is good, check that power is going through the switch.
I can't find motor brushes for the jack hammer. Any idea where to look?
You should be able to go to an electric motor repair shop and they can order them for you.Also check tool repair shops in your area.
Dewalt d25940k is a demolition hammer whith drill too?
No, the D25940K is not a Rotary Hammer. It is just a Demolition Hammer. (Jack Hammer). You can turn the chuck to adjust how your bit sits but that is it. Follow this link to the manual for this tool. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/581735-00,D25940.pdf
26helpful
2answers
I need the parts for rockworth power task 1700w
Hello I need a new trigger switch for my Rockworth PowerTask
serial no uk004984 ARPD1/OOK. On the switch itself inside it has HY15C. Please put me in touch with your on parts division. Thanks.
Top Electric Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electric Hammering Expert? Answer questions, earn points and help others
