I have a Viewsonic VS11531 27.5 inch monitor I use a OmniView® PRO3 16-Port USB & PS/2 KVM Switch. The monitor has a res of 1900 x 1200 but when I hook it to the kvm switch the display will not surpass 1024 x 768I have loaded the monitor drivers and use standard VGA drivers to know avail. Please help
It sounds like there is an issue of synchronization between the monitor and KVM. This will force the monitor into a lower resolution to sync them. You may want to check with Belkin to see if there is a firmware update for the KVM. There may also be a driver issue with one(all) of the video cards on the system. I recommend updating the drivers on all affected machines with the monitor connected directly to the individual machines. Rather than using generic drivers, I would use the drivers downloaded from the manufacturer of video cards and from Viewsonic for the monitor.
I have a belkin f1df102u and it does not seem to support 1440x900 resolution. Can anyone...
(More)
I have a belkin f1df102u and it does not seem to support 1440x900 resolution. Can anyone confirm?
have a 1987 chevy s-10 pickup truck has nopower to fuel pump keeps blowing out ecmi fuse need help...
(More)
have a 1987 chevy s-10 pickup truck has nopower to fuel pump keeps blowing out ecmi fuse need help trouble shooting have no elect.diagram.
