Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
What temp should freezer be set on in a hot garage?
  • 3,600 Answers
Commercial refrigerators are required to be set to 23 % a home unti shold not be less than 27% and thats for food being frozen to last 6 months.
Posted on Jun 28, 2009
  • 36 Answers
The temperature setting for the freezer has little to do with the ambient air temp. It has everything to do with how cold you want your things, and how much the door gets fanned.
The first thing I would do is to get the freezer out of a hot garage, into a cooler atmosphere. This is going to make your freezer last longer and more noticeably, lower your electric bill.
Posted on Jul 09, 2009
  • 232 Answers
The control was designed to be set in the middle of its range no matter where its put it measures the temp inside freezers and friges alike are not made to be in an area above 85* the hoter it is the more they will run $$$ a fan blowing at it can help keep it from running so mutch putting it inside would be even a better idea
Posted on Jul 01, 2009
Temp is 28 degrees in hot garage
One of three possibilities, Either the door is not closing correctly:or There is a bolckage or shortage of gas in the system or the surrounding outside temperature is to hot for the compressor to run correctly in. Place freezer in a well ventilated area. You will see a difference.
Jul 17, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer and fridge stop working when home temp is cold
ketner1 what you are looking for is an old style freezer. They ran so hot that they didn't care what the temps in the garage was. Here is a suggestion. I am not sure what kind of freezer you have had, but look for one that doesn't have a coil on the back of it. Freezers with the condenser in the cabinet work well at the temps you are looking for, however they don't work well in garages at 90 degrees, then they just transfere the heat to the inside of the freezer. This is the style my parents use and theirs is in a storage shed with no heat.
Feb 02, 2008 | Freezers
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
613 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
