Question about Extreme Networks (45210) Networking Switch
Failure to boot an Extreme Networks 8808
I am having problems booting up the Extreme 8808 switch. If I have a terminal session connected to the console port I notice the following:
Boot Module 05 MAR 00 v6.2
Memory Size: 10000000
Press spacebar for boot menu
UART test in progress....
UART test passed.
CPU memory test in progress...
Then it will hang before it reboots. It will never boot up.
So what I have done is gone into the Bootrom menu via spacebar.
I have forced the config to load from flash. It starts to load the image and crashes with this:
Copyright (C) 2000 by Extreme Networks
Version 6.1.4 (Build 12) By Release_Master on Fri 06/23/2000 4:23p
System Serial Number: 0031S80003
Memory Size: 1869309795 (1782MB)
Address load Exception
Exception Program Counter: 0x801b4580
Status Register: 0x34008d01
Cause Register: 0x00000010
Access Address : 0xef0b6763
Task: 0xef0b64e0 "tRootTask"
I have tried booting with all the cards pulled out just to see if one of the modules was causing this, still no luck. Any suggestions on how to get this to boot?
I am hoping it is just a software problem but suspect it might be hardware related.
Your input is greatly appreciated.
It sounds afraid... the switch may may be developing multiple sclerosis on its circuitry or the processor is losing it. have it checkd.
Posted on Feb 18, 2008
When turning on it flashes ck cable. and cables are fine
Possible connector issues or maybe hdd? Have you checked the bios for missing items?
Mar 11, 2015 | Compaq Computers & Internet
AT-8000GS/24 reset password with out reset button
Forgot or lost the password
Contact Allied Telesis Technical Support for assistance.
Apr 22, 2014 | Allied Telesyn ?AT-8000GS/24PoE 24-Port...
Locked up
Serial into it and power it on. As soon as it says it is loading hold down space bar. That will get you into the boot
May 21, 2013 | Extreme Networks Summit X440-24p - switch...
My switch don't boot up. it stops after displaying systme serial number
Hold down space bar while booting it up. From there you can clear the config.
Jul 12, 2011 | Extreme Networks Summit 24e2 Networking...
I need reset password of my summiti x450e
Hold down space bar while booting to access the boot loader.
May 18, 2011 | Extreme Networks Summit X450e-48p - Switch...
I dont know where to find the password can you help me ?
By default, the CLI does not require passwords. However, if someone has configured a password for the device but the password has been lost, you can regain super-user access to the device using the following procedure.
1) Start a CLI session over the serial interface to the Brocade device.
2) Reboot the device.
3) While the system is booting, before the initial system prompt appears, enter b to enter the boot monitor mode.
4) Enter no password at the prompt.
5)Enter boot system flash primary at the prompt. This command causes the device to bypass the system password check.
6) After the console prompt reappears, assign a new password.
Feb 07, 2011 | Foundry Networks FastIron® Edge...
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron# configure terminal
FastIron(config)# enable super-user-password test
FastIron(config)# write memory
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
Extreme Networks (45210) Networking Switch Logo
418 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
