Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi vs 45605 flickers
Our tv used to flicker until it was warmed up (3 to 5 minutes), now it always has a slight flicker in the picture regardless of how long it's on. Otherwise, it works great. Need easy maintaince???
Mine just flickers until it warms up and then it's fine. I was told " Most commonly this is caused by a couple of capacitors on the signal board that need to be replaced...You need to change C2P08 and C2P05 on the signal board, these are 100uf 16 volt caps. I would put in 100uf 25v caps if I were you".
If you can solder, you can probably fix it for less than $5.00. I am going to (hopefully) fix mine as soon as I can get to Radio Shack and pickup the capacitors.
Posted on Dec 14, 2009
  • 100 Answers
Looseconnections.
Posted on Jun 28, 2009
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
My screen looks like the tracking off. It wount stop flickering
Some electolytics on a small regulator IC are going bad. Take it to a shop.
Apr 30, 2009 | Mitsubishi VS-60707 60" Rear Projection...
Veertical lines
Put a fan in it. Something is overheating in the unit and by placing a small fan in the back, inside the back cover, the lines disappear. Hope it works for you, it did for me.
Sep 07, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
VS-45607
sounds like a defective cappacitor or leaky diode in the deflection circuits. Unless youre comfortable working around the high voltage circuits of a rear projection set, it may be best to call a reputable repair facility that is famillair with mitsubishi products.
Jun 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs 45605 no picture
yes if the tuner is out and you want to save some money then running an external set top box or your denon are fine. more often than not you will also have better picture quality.
May 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Flickering t.v.
There are bad capacitors in the power supplky and or the PIP board. if you have no solid state repair experience, call in a pro to assist you in this repair. Good Luck
Apr 07, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
Jan 24, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
460 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
