Question about Exercise & Fitness
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
Sportcraft tx 2.5 shows code 3 and stops after a few seconds of running time.
If you wish to get some details treadmill repair and error code ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 07, 2016 | Sportcraft Exercise & Fitness
Tx 5.0 rc treadmill by sportscraft, manual
Did u find out the problem? Mine just started doing the same thing.
Apr 13, 2013 | Sportcraft Exercise & Fitness
Error code E0
1) adjust the speed sensor see the diagram attached. tight the cable, and clean it.
2)test the input voltage motor, if there are the motor need repair.
3)test the output voltage from the motor controller, for input voltage motor if there are NOT the motor controller need replace.
God bless you
Nov 08, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Tx 2.5 is on 7
To reconfigure the controller to factory setting:
1) Hold both the "Mode" and "Stop" buttons down while removing the magnetic key.
2) While continuing to hold both buttons down, replace the magnetic key. All the lights will light up and "beep".
3) Whille continuing to hold both buttons down, press the + button.
It should now be reconfigured.
I hope this helps
May 28, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
E5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Nov 24, 2011 | Exercise & Fitness
My TX 5.0 RC Sportcraft Treadmill stops and show in the screen a #3... Start normal, but in seconds stops... I want to know how to fix it... Thanks...
You will have to unscrew that part out of the treadmill and take it out, and then put it back in to see if that makes any difference. If for some reason that does not work, you may have to contact the company to get a replacement on your treadmill, or to see if they wil fix it for you. Since each treadill is different, defects are inevitable, so a person will have to use consider going this route if all else fails.
Jul 13, 2011 | Exercise & Fitness
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
I have a sportcraft tx 2.5 treadmill thats needs it stops on 7 sec evertime i moved and lost the manual to it what should i do
Can you give more details? are you saying it stops 7 seconds after you step on it, (every time)?
If so, have you had the treadmill a while? this is an indicator of a worn belt. the belt is not sliding like it should, and drawing too much current. your control board will 'clip' the current off after a pre-set time, to avoid burning up components.
other things it could be:
1. your belt is too tight. did you tighten it lately? When did your treadmill start doing this?
2. The motor is going bad, and drawing too much current.
3. motor control board is bad.
look at your motor's current rating: measure the current draw when you get on it. if the current draw is ~ 80% of the rated current of the motor, and your belt is good,..and not too tight, it could be the motor.
if the treadmill is stopping while only drawing 4 or 5 amps, I would lean towards the control board is bad.
cheapest way to get started troubleshooting. Ensure the belt is not too tight, (adjust to only about 3 inches slack, when you pull up on it). next. buy some belt lubricant and lube it up.
If this doesn't fix your problem, keep looking for other fixya help. someone with SportCraft TX 2.5 specific experience. Sorry, I only have generic help here.
good luck.
Jan 25, 2010 | Exercise & Fitness
Turned on, runs a few seconds, shuts off with a #3 on display
Contact the manufacturer. You need the optical disc. It is the speed sensor. Eric For Treadmill replacement parts, please contact our Consumer Affairs Dept. at (800) 526 - 0244
Aug 06, 2009 | Exercise & Fitness
Exercise & Fitness Logo
2,827 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
