Can i reset the remote for my air conditioner? it
Can i reset the remote for my air conditioner? it doesn't work anymore. batteries are good~needs to be reset to airconditioner if that is possible
    Sergeant:
  • 340 Answers
They are not resetable. did it get wet? Good luck Tom
Posted on Jun 28, 2009
I,m having trouble setting the remote for this machine. i have hit the reset and that didn,t do anything. can you help me please
Make sure you have good batteries in the remote. Then if nada works the problem lies with either the hand remote or the receiver part in the AC.
Jul 18, 2015 | Danby DPAC90061 Portable Air Conditioner
Rfl 0601el
Your old batteries may have leaked and now battery connections are not good. Clean them with a q-tip and rubbing alcohol then use a pencil eraser to further clean them up. Install batteries and spin them with your thumb to seat them, silly huh? Press reset while pointing remote at unit. If all that does not work you may need to call tech support to program the remote (not fun).
Sep 25, 2013 | Heating & Cooling
My Climette wall air conditioner do not recognize the remote anymore. The remote is on (new batteries) the ac works with the force switch. Just suddenly no talking between the remote and ac?
Try disconnecting the AC power at its source. Wait for a minute or so, connect the AC power source again, and try the remote. Sometimes the AC has to "reset" for the remote to work again
Sep 01, 2013 | Heating & Cooling
The remote for my Tubo Air TAS-12 doesn't work. Are there batteries inside or do I need new one?
does the remote come on? if not then yes i suggest changing the batteries, some remotes have a slide that covers the buttons pull it down and take it off you should see the batteries when that is removed, or some are at the back, let me know if that helps
Sep 24, 2011 | Turboair TAS-12 Air Conditioner
Air conditioner was working great suddenly STOPPED working...cant turn it back on.
Hello
Is there a reset button located near the plug? If so reset it.
Check your circut breaker for the outlet its plugged into also.
If your using a remote to start this unit check that the battery is good in the remote,it may only work with a remote.
Jul 21, 2011 | Kenmore 76129 Air Conditioner
Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Mar 15, 2009 | Whirlpool ACC108PS Air Conditioner
Remote won't work
The remote stopped working. So I changed the batteries Then remote signal's are OK But Indor Unit is not controlled by remote.
Feb 01, 2009 | LG LSC121PMA Split System Air Conditioner
Remote's functions dont control the air con anymore.
Have you checked the battery's in your remote?
Jan 30, 2009 | Heating & Cooling
We have a fujitsu reverse cycle air conditioner. Last night when we went to turn it off with the remote it did not respond. We needed to turn it off at the switch outside the house. We replaced the...
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective.If the remote control still good try to press the RST or RESET button on your remote control and try. If wont works it means that the reciever board in the indoor unit is defective.
Aug 20, 2008 | Fujitsu Heating & Cooling
Air conditioner remote
- check if the battery is still good
- check if the receiver of the unit is clean and no obstruction.
- Some of remote control have a reset switch, every time you change it with battery you have to reset it.
- Some of remote control have A and B selector at board and remote control, check this if they set at the same frequency.
- To check if the remote control still working you have to test your remote control to other unit with same model as yours. If its not working then replace your remote control. But if its working then you have to replace your receiver board.
- Some remote control have to be reconfigure so you have to read your manual.
Dec 29, 2007 | Heating & Cooling
Heating & Cooling Logo
484 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
