Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works on my Dometic rm2804 but the fridg isnt
I had a bunch of frost built up on the back coils and i melted all the ice off and now it wont even get cold at all and this happend a cpl days ago.Is it the coils or what is the problem if someone could please help me before i keep waisting money on food just to have it go bad
    Sergeant:
  • 222 Answers
How did you remove the ice? If you used a sharp object, there's a very good possibility that you punctured one of the lines that carries refrigerant through the system. If the refrigerant has escaped, there will be no cooling in either the freezer or the refrigerator compartments.
Possibly the coil and/or lines can be repaired, but most likey if it's the evaporator coil, it will have to be replaced, and this is NOT something the ordinary homeowner can tackle. It requires specialized equipment and materials not generally available to anyone but licensed HVAC service people.
This is the only explanation I have for why the unit would completely quit working after ice being removed from the coils.
Posted on Jun 28, 2009
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
My fridge works fine but sometimes the freezer will stop working and you can here a sizziling sound coming from the back like water dripping and hitting something hot. I unplug and plug back in and it...
Hello, welcome to FixYa.
This is just the normal operation...specifically the defrost cycle every frost free unit must cycle through every 8-12 hours.
You are correct, the sizzle is water (from the melting ice) dripping onto the defrost heater. It is all normal so no need to worry.
Thank you for choosing FixYa today. Please take a moment to rate your experience here.
Regards,
Macmarkus :)
Aug 15, 2011 | Kitchen Ranges
New Frig..just l yr old. Water droplets on floor below bottom pull out freezer compartment. Discovered a layer of ice built up inside below the racks. Can't find anything in the manual to indicate...
Your drain is plugged. When in defrost mode the heater comes on in freezer and melts the frost on coils. Sometimes the frost falls off in a chunk and covers the drain. The heater can only be on for so long until the bi-metal/ defrost thermostat shuts it down. Once the defrost cycle ends the frost turns to ice and builds from there. Your heater is melting the frost and the water has no place to go so it goes under the racks.
To fix remove contents off freezer and remove racks. Remove the back panel 4 screws and you will see your drain plug under the coils. Remove any ice you can see blocking the plug. Now pour hot water into drain until it flows into drip pan under freezer. You can remove back access panel behind fridge at bottom. Once water flows freely though than replace the access panels.
If you leave fridge plugged in while doing this be careful.
Aug 01, 2011 | Maytag Refrigerators
My refrigerator is not cooling everythings seems to be working fine and I can hear the flow of refrigerant but it is not getting cold. Is it possible that it needs more refrigerant
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 10, 2011 | Dometic Refrigerators
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
My dometic refrigerator rm2852 is freezing up.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Dometic RM2852 Refrigerator
Dometic RM763. Freezer=Yes,Fridge=No
Aug 21, 2009 | Refrigerators
Problems with fridge
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. Look at the heater; It will be at the bottom of the freezer on the back wall. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Usually on a circuit board and expensive. Good Luck, Jeff
May 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
311 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
