Question about Maytag Refrigerators
Maytag Plus.RSW 2250AGE Serial 10442944 SY approx 10 year old fridge/freezer. Problem with glass element in freezer keeps blowing.It has been suggested that it needs a new heater kit and defrost thermostat.Please advise your opinion on the problem and the price and availability in Australia. thanking you in anticipation.... jks.
    President:
  • 1,197 Answers
Freezer defrost element (element within a glass tube)......Self defrosting freezers have an element that melts any excess frozen condensation in the back of the freezer.
If it trips its recommend checking the compressor for burn out unless you know for sure the elements have direct short causing this to happen. I think the compressor may have a short, start relay,or start capacitor is defective... its probably a short sumwhere swhich is causing this issue repeatedly.... first have an electrician to test for any short circuit anywhere.... and then replace the defrost heating element.... before going in for a heater or defrost thermostat
u can find the parts, exploded diagrams and the wiring diagram for ur maytag model in the below link
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=RSW2250AGE&mfgModelNum=&fkMfgID=1
good luck
if u felt i spent time for u... kindly rate my service.....
Posted on Jun 28, 2009
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
Compressor conning on for only approx 10 seconds and off for approx 30-60 seconds continuously. Freezer not cold enough to keep things frozen
Check condenser is cleaned. Replace relay and check compressor is working. If working keep your arm on condenser coil to feel warm. If not, no gas int he system. Call repairman to rectify. And also keep fridge temp setting between 36*F and 46*F and freezer temp between -14*F and 8*F. Thanks.
Feb 12, 2011 | Maytag MTB2195AE Top Freezer Refrigerator
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
My fridge clicking, buzzing and then clicking back off. Inside it was starting to warm up and was starting to leak water onto the floor. Today someone came out and replaced the relay. After 4 hours the...
Hello, no if the compressor is still running and you are not hearing the click you should be ok. It will take approx 8-10 hours for it to get to normal temp. The frost you mention on the freezer panel could be a problem with the defrost system. I would leave it over night and check it tomorrow. If there is a major ice build up comment back and i will assist you further. Mike
Oct 19, 2009 | Maytag Refrigerators
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Why does my maytag fridge drip water around the freezer door?
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Mar 23, 2017 | Sub-Zero 650 / O Bottom Freezer...
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Refrigerators Logo
43 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
