Question about Hoover F5835900 Upright Steam Vacuum
Hoover f5835-900 will not pick up water. seems to be blowing air
Out. i have put the water down and now cannot pick up dirty water. what is wrong
  • firehead May 11, 2010
    Can you hear the vacuum motor running?
  • 174 Answers
Hello
Click HERE toget the manual. Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Posted on Jun 28, 2009
  • firehead Jun 28, 2009
    Hello again. Sorry, I just discovered that the link I gave you won't work anymore. If you e-mail me at firehead@rogers.com I will send it to you.
Carpet cleaner suction not working blowing out air instead
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Jul 25, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steam vac spin scrub that won't pick up the dirty water heeelllllllppppppppppppp please
Jun 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
This machine will blow air instead of ****. Any advice?
The most common reason no suction up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood. Warm air is normally blown out through the bottom of the machine to warm the carpet.
Apr 29, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steam vac spin scrup with clearn surge that wont recover that water from the floor, everthing else seems to be working, we looked for a wet button but could not find one, any thoughts
Feb 19, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Not picking up in tank
There are a few things to check. First make sure the front panel is installed (the square part that is removed for using the hose). Next make sure the lid has snapped in place. Next, remove the lower tank and look for the round tube for a rubber seal, should be on. I have found these to be the most common problems relating to your suction issue. Also verify that it actuallu is putting water down ( this is another issue).
Apr 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaner does not **** water it blows
push the little square thingy down on the very front of the bottom bucket, then put the lid on before you put it on the machine, then let the force of putting it together push the front thingy up when you put the bottom bucket on the machine as one assembly..... it makes the seal right somehow..... ....my wife about pulled her hair out before we figured it out the hard way...... I may get a reward tonight......
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Not Sucking the dirty water
It seems that when you emptied the recovery tank it has not been placed back proper.
please make sure it is sealed else you will loose suction
Jul 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
HOOVER SPINSCRUB WONT SUCK UP WATER...BLOWING AIR OUT
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Hoover F5835900 Upright Steam Vacuum Logo
801 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
