Question about Microsoft Windows XP Home Edition for PC
Sony VIAO Desktop Computer HAL.DLL file missing or Corrupted.
A game wasnt working, said the Paged Pool memory was out. So i looked up how to fix it. It said to change the Windows Paging File or whatever... it worked for a bit. But then i looked at it and thought it must be only doing it on the C drive, not the biggest drive D. I changed the settings for the Paging File for D. And i deleted the numbers that were on C so it wouldnt use that drive. Then I rebooted and it, im guessing, is only checking the D drive when starting up, and Says HAL.DLL file missing or corrupted. It never once shows anything about setup or BIOS so i cant change that. It just restarts when I press any key... HELP!!!
  • 428 Answers
Did u remove the pge file from C:...mmm u have to set it there.If hal.dll is missing here what u have to do.
HAL - Hardware Abstraction Layer
HAL is Microsoft's abbreviation for the Hardware Abstraction Layer, the technology and drivers that let the Windows NT, 2000, and XP operating systems communicate with your PC's hardware. HAL is one of several features--along with the NT file system (NTFS) that replaced the much less secure MS-DOS--that make NT-based operating systems more secure and reliable than Windows 95, 98, and Me.
HAL prevents applications from directly accessing your PC's system memory, CPU, or hardware devices (such as video and sound cards)--a method that can prevent many device conflicts and crashes. Unfortunately, HAL sometimes also slows or stops DOS games and programs, which need to load their own memory managers or control hardware directly for better performance.
With HAL in the way, developers must rewrite or even abandon their older software in favor of newer, HAL-compatible versions. Microsoft has pressured hardware makers to provide or support technologies such as MMX, DirectX, and 3D graphics language OpenGL, all of which allow fast but indirect access to the advanced high-performance features of video, sound, and CPU hardware. Such access also makes for a better visual experience when using Windows for Web and productivity applications; improved graphics performance is evident all over Windows XP's new user interface.
XP also offers some new compatibility-mode features that let you run programs meant to run under earlier operating systems, but, frankly, most DOS-based and even some Windows-based games simply won't work with the new OS.
So what you have to do is to boot from the CD.
Change the boot menu appropriately.
Then go to Recovery Console. Pressing R when the XP installation window comes up.
Then in the repair mode do the following.
Type this and Enter. .
expand X:\i386\hal.dl_ %systemroot%\System32\hal.dll
System root is the partition which holds Windows installation. So if its in C and if your CD drive is E...It has to be modified like this.
expand E:\i386\hal.dl_ C:\System32\hal.dll
This will solve ur problem. Remove the game from using safemode also. (Press F8 to go to safemode befor Windows boots).
This will solve ur problem. If it couldn't, do this.
Type each with an Enter.
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini
DEL C:\Boot.ini
BootCfg /Rebuild
Fixboot
If this solution helps you, Please RATE the answer kindly. :)
Wish U Luck.
TC.
Posted on Jun 29, 2009
Testimonial: "Thank you so much, helped a lot, I saw a lot of Recovery Console stuff on Google but none of it helped, but this worked perfectly! Thanks :)"
Missing or corupt hal.dll
Welcome to Fixya! hal.dll is required to communicate with your computer hardware. If this is missing or corrupted. The computer might end up not booting. You need to restore the Windows OS of the computer to resolved this.
Click the link below for further assistance:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=15511
Thanks
Nov 02, 2011 | Gateway 505GR PC Desktop
<windows root>\system32\hal.dll file is
Resolution
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
7. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
8. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
9. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, you should understand that you will lose them all if you continue with a clean installation of Windows XP.
10. Test the hard drive. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive but you'll want to test it to be sure.
If the drive fails any of your tests, replace the hard drive and then complete a "new" installation of Windows XP.
Mar 09, 2011 | Microsoft Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Missing file or corrupt in system32 hal.dll
Dear User,
Try to download the hal.dll file from here.
http://www.dll-files.com/dllindex/dll-files.shtml?hal
You will get one popup download the file after donwloading you have to unzip to c:\windows\system32 folder.
Mar 03, 2010 | E-Machines eMachines Desktop PC
Hal.dll file missing or corrupted
Follow the steps given in the link below to troubleshoot the hal.dll missing issue:
http://support.microsoft.com/kb/945380
Aug 26, 2009 | Microsoft Windows XP Home Edition with...
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
\system32\hal.dll. MISSING FILE
YOU NEED TO DOWN LOAD THIS PROGRAM FROM MICROSOFT.
WWW.WINDRIVERS.COM/HAL.DLL
OR
WWW.WINDRIVERS.COM/SYSTEM32/HAL.DLL
ONLINE ADDRESS BAR: WINDOW DRIVERS FOR SYSTEM32\HAL.DLL
OR FIND THE FILE IN THE ORIGINAL SOFTWARE YOU INSTALLED THE WINDOWS VERSION ONTO THE SYSTEM
ROD
Feb 12, 2009 | Acer Aspire 5000 Notebook
Hal.dll file missing, can't boot from xp disc as error states hard drive cannot be detected
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Nov 15, 2008 | Computers & Internet
Microsoft Windows XP Home Edition for PC Logo
412 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
