Question about ViewSonic VX710 17" Flat Panel LCD Monitor
Viewsonic 710 comes on then after 3 seconds shuts off
Problem was addressed with the vx715 model but what about the vx710. Capacitor numbering is different and there is no obvious burnout of any area on the main board?
Stumped in bama
3 Suggested Answers
SOURCE: ViewSonic VX710 On and off
On every one of these monitors that I've repaired this issue has been due to badly overheated, blown capacitors. On one it was a single cap that cost 80 cents. On this model I had one that had 5 bad caps on the power board and it cost several dollars. Usually the bad ones are obvious sometimes I've had to do the simple ohm meter test. All have been easy fixes: a trip to the electronics store and a little soldering.
Posted on Nov 28, 2009
budmrtn
  • 11361 Answers
SOURCE: Yea my ViewSonic VX710 takes and it will flash on
Yes, do look for caps with bulging tops as shown in my pictures, you should replace them in a set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX710_910/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Jan 12, 2011
I need the operating manual for this model
Try Googling (brother)(Vx710)(manual) without parens.
Feb 23, 2018 | Brother Sewing Machines
Have just upgraded to windows 7 and my Viewsonic vx715 is only recognised as a generic PnP monitor and I can't load drivers from disc supplied. monitor is approx 6yrs old and still going fine!
In most cases you don't need the drivers for a monitor to work completely fine. In order to obtain your drivers you can always check the manufacturers website and they should have drivers listed, in your case they do. Although I couldn't locate VX715 i found many VX models in the driver search. There should be one that works fine, just make sure you download the right right IE: windows 7 x32/86 if your running a 32-bit operating system, or windows 7 x64 if you are running a 64 bit operating system. Here is the website I located http://www.viewsonic.com/support/downloads/drivers/
Jan 09, 2011 | ViewSonic VX715 17" LCD Monitor
Monitor turns on for one second then shuts off
Possibly failing power capacitors, needs to be checked by a TV repairman
Dec 30, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
My viewsonic vx710 lcd monitor shuts off after @ a hour of operation then won't come on for @15 minutes
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 31, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
My View Sonic VX715 LCD sometimes will come on with the top of the screen darker and it will lighten up towards the bottom then go completely dark. I found buy tapping on the top of monitor it will come...
fixing a LCD monitor require you to have some basic electronic know how.. changing the backlight won't be easy as you need to dismantle the whole LCD right to the screen..
But if the display only lasted for few minutes and then the whole screen turn dark, this is due to bad component on the board.. most probably capacitor...
May 24, 2010 | ViewSonic VX715 17" LCD Monitor
Viewsonic VX710 17" Flat Panel Display. It turns on and after 1 or 2 Seconds shuts the backlight off L.E.D. satys on but the backlight won't comeback on. No cap seems to be blown up.
Failed cap amy not show any sign of bulging or leaking, it can still have high ESR. You can also have components failure in the inverter circuits such as shorted inverter transformer driver transistors, open or short winding (DC Ohm test will not show shorted turn, need to use ringer test), I use SENCORE LC75 for testing, bad lamps or bad soldering works on the lamps. See http://s807.photobucket.com/home/budm/allalbums for some guide.
Mar 31, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
You may have bad transformers, need to be checked, DC Ohms meter may not be enough, need to use inductor tester (I use Sencore LC75). You can also have bad lamps (bad solder connections). The caps may not have any sign of bulging but can have high ESR, see some pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
The "back light" has probably failed. If you shine a light on the monitor while on, you might see that the program is displaying, but because the light is out, it can't be seen easily.
The back light is a fluorescent lamp or tube that may be difficult to access, depending on your level of ability and tools available. While most lamps can be purchased for relatively little money, it may not solve the problem. Like all fluorescent lights in your home or work, there is a second major part - the ballast. If either of these fails, the result is no light.
Lights and ballasts (sometimes called inverters) are specific to monitor model and costs can vary significantly. You should determine costs for your monitor and decide whether or not taking the monitor apart is something you want to do before buying the parts.
Sep 22, 2009 | ViewSonic VX710 17" Flat Panel LCD Monitor
Viewsonic vx715 17" lcd turns on but goes dark in like 5 seconds
You need to replace your Inverter board or replace the 2 black caps on the power supply board wich are labeled 1000uF 16v ELITE. that will cure your problem. Glad I Could Help!
Apr 08, 2009 | ViewSonic VX715 17" LCD Monitor
ViewSonic VX710 17" Flat Panel LCD Monitor Logo
291 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
