Question about Pentair PUREX MINIMAX HEATER; THERMOSTAT, 60 CAPILLARY - 072022
Jandy lite2 heater
Why would i have an igniter failure again, F4 on panel.on a heater that is 5 years old and has had a new igniter replaced already? This is my second igniter on there now.
  • fabermill62 Jun 28, 2009
    dont know about voltage.But igniter was replaced lj-400n is the model # on the work order.the original was replaced in 07.now the replacement just crapped out...Thanks for your help.
    Faber
  • fixem2 May 11, 2010
    What voltage is the module set up for? 120V or 240V? What happened to the last ignitor: broken, shorted or out of tolerance on the resistance test?
    Champion:
  • 246 Answers
T problem is not at the ignator but t flame rectification need ignator kit and flame rectification kit
Posted on Sep 18, 2009
What part failure produces error code FL 4?
igniter failure. this is a problem with either the hot surface igniter, or the main circuit board. if the problem is the board you must replace the high voltage chip along with it
Aug 18, 2014 | Jandy Lite2 Heater LJ175P - 175,000 BTU LP
Laars lj 400 heater has blown both inline fuses. Hot surface ignitor was replaced and new fuses installed. Both fuses burnt again. Safty curcuit was bypassed and fuses replaced again. BURNTagain! upon...
It is likely the voltage selector board, the smaller of the two, that is bad. In the past Jandy has recommended changing the heater over to 115V as a better option if you keep loosing the board(s). I forget their exact logic as to why but the last one of those I had behave like this was a few years ago and once we replaced all the burned up electronics and converted the power and the heater over to 115 it never failed again.
Perhaps Jandy would explain further if you need additional info, try calling:
1-800-822-7933
Sep 08, 2011 | Jandy Laars Lite2 Lj 250,000 Btu Heater
I have a Lite2 heater that is about 4 years old set up to use 220. Worked great up to now. The fuses on the igniter blow out when it tries to light burner. Replaced the igniter and no help. It appeared the...
Check for a shorted or frayed wire. Rodents like to nest in heaters, and you could be experiencing a fault to ground, causing the fuses to blow. It may be in the harness. You can test for continuity to the heater cabinet. It may be in the wire going to the ignitor, that is why it doesn't blow the fuses until power is sent to the ignitor. There also could be a problem with the IID.
May 17, 2010 | Jandy Digital Lite2 Lj250 Btu Heater,...
Pool heater will not come on
sounds like a plugged pilot - pull it out and clean it, should fire right up
Sep 01, 2009 | Jandy Lite2 LJ125 Ceramic Gas Heater
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
I have a Jandy Lite 2 Heater model LG250N
You don't use heater very often. make sure you clean gas nipplets from web, wasp nests try that?
Jun 12, 2009 | Jandy Lite2 LJ125 Ceramic Gas Heater
Jandy LJ250N pool heater turns on - runs 10 minutes then stops
FL 2 is ignition failure,
If it ignites as you and the heat icon comes on, then it quits it sounds like you are losing gas pressure, no gas flow or it is to low, or air is in the gas line, if there is ignition then your flame sensor is not sensing the flame. or it needs to be replaced.
Apr 30, 2009 | Jandy Digital Lite2 Lj250 Btu Heater,...
Pentair PUREX MINIMAX HEATER; THERMOSTAT, 60 CAPILLARY - 072022 Logo
202 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
