Question about Electrolux Dryers
Simpson dryer diagram
I HAVE MIXED UP CONDUCTORS...NEED WIRING DIAGRAM !
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: need a diagram on how
Hi and welcome to FixYa, I am Kelly
Take a look at diagrams A - M of this link: (12 of them)
http://www.repairclinic.com/Dryer-Belt-Diagrams
I know it does NOT list the Simpson Sirocco 500 at all. However, just look at the type / installed point of the idler pulley and SPRING that you have and one of them for sure will match your dryers belt routing.
If this does not help you or does not help you, just respond here and I will gladly help you at that time.
Thanks for choosing FixYa,
Kelly
Posted on Mar 02, 2011
I have a simpson evolution 904 oven and the wiring diagram has been lost , would you have a copy
LOOK UP ON LINE TYPE IN SIMPSON EVOLUTION 904 WIRING DIAGRAM SEE IF YOU CAN FIND ONE THAT WAY. IF NOT TRY THE LIBRARY.
Jan 28, 2015 | Ovens
How to wire Simpson 1200S dryer motor
Check with Simpson directly to obtain the diagram.
Jun 10, 2014 | Dryers
I have a Tork 1103 24 hour time switch and I need directions on understanding the wiring diagram.
I assume this is the wiring diagram you have for your timer. I don't know what you're trying to control with this timer, but it has a 110V timer motor so it must have a neutral conductor connected. The L terminal would be your incoming line conductor (hot, usually black) The X terminal would be your Load terminal (usually black too) The unmarked terminal would be your neutral conductor. The incoming and outgoing neutral conductor would be connected here (usually white) If you're using this for 220V load, the hot conductor would be connected to the terminal marked 1 and it's load connected to the 2 terminal. Or you could use it for two separate circuits4591020.jpg
Aug 13, 2010 | TORK Variable Cycling Timer 8601
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
Replacing the belt on a simpson 362 maxidry
Check out applianceaid.com good easy site to follow
Apr 19, 2009 | Electrolux Dryers
Simpson dryer 1200p motor wire install
obtained the circuit diagram from the supplier
Aug 31, 2008 | Dryers
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
I need a wiring diagram to wire my oven to the house power. Whirlpool electric model# rb260pxyb
You will have 3 or possibly 4 wires coming out of the oven Red and Black go to the hot leads in the junction box.Usually red & black but could be 2 black. White goes to white Bare/green go to the white if no Bare/Green available. This is for a wall oven. If the stove is free standing and you want to attach a cord. Just buy the cord that matches the outlet in your house. Make sure it is a range cord and not a dryer cord. They are very similar. If a 3 conductor cord (most common) outer two terminals are the hot ones. There is a wire or metal strap between the frame of the range and the center (neutral )terminal . On a 3 conductor cord leave this connected. On a 4 conductor cord remove this wire and connect it to the green/bare wire in the cord. There may be a vacant terminal on the block for this purpose. If not use a wire nut.
Jul 06, 2008 | Whirlpool Kitchen Ranges
Wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Oct 27, 2007 | GE 30 in. JP326 Electric Cooktop
Dryers Logo
243 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
