Question about Kenmore HE2 Plus Front Load Washer
Our washer is not spinning, either during the wash cycle or during the final spin. What could be the possible causes of this?
  • 15,935 Answers
It appears your timer/main controller/CCU or door latch/switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Nov 18, 2017 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Hi, My washer does not do the final spin.....Everything else seems to work except the final fast spin. Is there anything i can do?
Stop using so much soap? These newer washer must use a slight amount of HE soap. Any other thing will cause motor over amping, burn up sensors, and cause the control to work overtime trying to remedy the problem. F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 29, 2010 | Whirlpool Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
