Question about Troy Bilt 5.5hp Self Propelled Mower
Mower will not start....there is gas and oil in the mower
    Problem Solver:
  • 11 Answers
I had the same problem and it was my kill switch on the left of the motor the cable hooks up to the plate was sticking so when you hold the lever it doesn't disengage the kill switch fully i sprayed wd40 all through the plate to lube it up try that hope it works
Posted on Jul 23, 2009
  • 1,041 Answers
You willneed to disassemble the carburetor and spray with carb.cleaner.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
I have Gas in my oil sump and sprays mixture out exhust when trying to start mower
what has happened is the rubber seal on the needle and seat has dried out and fuel is leaking passed then the carb overfills and then the gas flows into the cylinder and crankcase
Sep 03, 2012 | Craftsman Garden
John Deere LA110 riding mower has gas in the oil
Try stripping it down and having alook sounds like the piston ring has snapped and is pumping gas into the oil that would explain why the oil is coming out the the exhaust the black smoke is just oil burning up ou also might want to clean the carb alittle too.
Mar 19, 2012 | John Deere 22HP Hydrostatic 42" Riding...
I have a Snapper Yard Cruiser with a Kohler 15 hp OHV engine. Family no.SKH426U1G2RB; model cv15s; spec.no.41570. I bought this mower new and started having fuel troubles after about a year. My dealer...
I HAVE THE SAME PROBLEM. As soon as you shut the mower off, lift up the seat and turn the gas shut off to the closed position. Do this even if you are only going to be off the mower a few minutes. When you need the mower started again, open the gas shut off and start the mower.
Sep 12, 2010 | Omega Rear Drive Wheel Snapper Mowers
My son poured gas in the oil line. i dumped the gas out but the mower will not start now.
Open the oil drain plug let out all oil and let sit open for a few days. Then fill with some new 30W and try to start again.
Jun 23, 2010 | Toro Lawn Boy Self Propelled CARB Walk...
Oil change
STOP !
Your lawn mower is has a 4 cycle engine
It does not require oil to be mixed with the gas
The oil for the crankcase should be a 10W-30 or 10W- 40
NO GAS IN THE OIL
What you have is a 2 cycle oil that is mixed with gas for most weed eaters, chain saws, ect
Putting a gas/oil mix in your mower WILL severely damage it destroying the main bearings and could lead to an explosion or fire.
Please be careful
Apr 04, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
What is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Mar 29, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Troy Bilt 5.5hp Self Propelled Mower Logo
356 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
