Question about Gateway nv Computers & Internet
What does it mean when the charging indicator light is orange and blinks every 5 seconds?
My laptop has been shut down for a while because I had to get a new ac adapter for my laptop.
SOURCE:
map9966
  • 2351 Answers
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Posted on Mar 14, 2008
olwork
  • 237 Answers
SOURCE: Inspiron Battery Light Flashing Orange
Battery.
Dell has a chip internal to the battery programed to shut down after a certain number of charge cycles. This means every time you plug the laptop in with the battery installed. When it reaches this determined number the battery effectively shuts down, even though technically it's still good. There have been loads of complaints on the net toward Dell over this issue. I have myself experience this. Battery good one day, powered down, went home, powered up... only to receive the deadly flashing light. Only cure is to replace battery. Several hacks trying to get around this but they're all horrible. Bad Dell - bad, bad Dell!
Posted on Jun 29, 2009
  • 262 Answers
SOURCE: I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
Posted on Nov 06, 2009
LaptopExpert
  • 458 Answers
SOURCE: My Toshiba Satellite AS205-5000, will not turn on
You Need To Replace the DC Jack..this involves desoldering the old/faulty dc jack from the motherboard, then cleaning the board, then soldering a new dc jack in place of the old...
But First, Test Your AC Adapter - use a multimeter (available at any home improvement store for under $7)...
Posted on Nov 15, 2009
smatney81
  • 31 Answers
SOURCE: WHAT DOES BLINKING BATTERY INDICATOR LIGHT MEAN ON A TOSHIBA SATELLITE LAPTOP P25-S5093
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Posted on Jun 17, 2012
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
Sep 13, 2011 | Toshiba Satellite M205-S4806 Notebook
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
After connecting the ac adapter the LED shuts down and the laptop is not working anymore.
Pls check if the battery is faulty. Does it work with AC Adapter only (battery detached from laptop) ?
Which LED shuts down? Pls provide more details.
Mar 04, 2011 | Dell Vostro 1014 Laptop Computer
Computer will start to power up and then shut down.
Could be burn out power supply or dead battery before buy a new one borrow from a friend similar adapter with similar ratings
Mar 02, 2011 | HEWLETT-PACKARD nx9110 AC Adapter - ...
I heard a "snap" noise and my laptop shut down
Most of the time when you hear that kind of noise and it was plugged into the AC adapter, a power surge hit your pc and it will need a new mainboard to power back on.
Sorry for the bad news.
C2Solutions
Feb 10, 2011 | Toshiba Computers & Internet
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
Mar 02, 2009 | ASUS AC Adapter- Universal Notebook AC...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
