Question about Singer CE-100 Futura Computerized Sewing Machine
Food pedal problem and alignment problem Singer Futura CE-100
I have a Singer Futura CE-100. My machine suddenly stop working because the foot pedal doesn't obey me anymore and I know the pedal is not broken. Also when I start the machine 1 time on 5 it's beeping because the needle alignment goes to far to the right that reach the presser foot. I do not know why the start position is off line....
Is anyone can help me?
Thanks in advance
HL
SOURCE: needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Posted on Dec 25, 2007
  • 89 Answers
SOURCE: Needle keeps hitting bobbin case
either your bobbin case isnt installed right or the machine's timing is messed up try to get needle loose or completly out is preferred then try turning it and see if it comes unjammed if so take your bobbin case out and reinstall it making sure it is in the fit right if this dont solve it then you need to get timing set (not recommended to do at home get pro to do it ) hope this helps you
Posted on Aug 20, 2008
SewTechWayne
  • 186 Answers
SOURCE: faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Posted on Jan 31, 2009
  • 23 Answers
SOURCE: Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Posted on Feb 27, 2009
  • 76 Answers
SOURCE: alignment of needle.
make sure the needle is positioned correctly and all the way up into the deedle slot. lower by hand and check again, if still doing so you can tilt the needly slightly befor tightning the screw. lower by hand again an see
Posted on Aug 27, 2009
Control pedal for singer 2000 sewing machine
They're available on eBay; it's the same pedal for ALL CE line machines, so if you see a listing for a CE-100 or CE-350 foot pedal, it's the same as the one for your machine.
Oct 04, 2014 | Singer CE-200 Quantum Futura Computerized...
My Futura machine sews and stops,sews and stops,whats is the problem?
check to make sure that the machine is plugged in to outlet correctly
and also plugged into the machine correctly
make sure the foot pedal is also plugged into the machine correctly
could also be a problem with the motherboard
or a problem with the foot pedal
if none of these suggestion help then the machine would have to
be checked
Dec 01, 2012 | Singer CE-100 Futura Computerized Sewing...
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
I lost the cd intallation of my singer futura ce-100 there's no way to make it work plase help me.
The installation cd of singer futura ce-100 is not freely available. You need to buy it. You can order for the installation cd at this link " https://cart.jennys-sewing-studio.com/", or you can contact Futura support at " http://futura-support.com/faq/machine.htm".
Hope this will help you.
Jul 12, 2011 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce-100 wont start
Do you still have the embroidery arm attached? If you do, the sewing function of the machine won't work.
Mar 24, 2010 | Singer CE-100 Futura Computerized Sewing...
My foot pedal started smoking on my Singer 413 Sewing Machine
Hi.
No solution I'm afraid - but it has just happened to me too on a 1975 singer 522 Machine. Like you just switched it off and am now sourcing a new pedal....did have a look inside the pedal but nothing obvious - smells horrible though and will not use until replaced.
Jan 03, 2010 | Singer CE-200 Quantum Futura Computerized...
My singer futura 600 will start for a moment then stops suddenly making a red flashing beeping sound. Is there a problem with the power pedal or what?
someone told me to take my pedal to an airconditioner repairman. i did. he cleaned and greased something in the pedal and now it works like a charm.
Apr 27, 2009 | Singer CE-100 Futura Computerized Sewing...
Beeping
I have had the same problem with my machine as well. have you tryed, keeping it hooked to your computer while sewing, even if you are not using your embroidery unit it still needs to be hooked up, that seems to have helped some with the beeping.
Feb 10, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
172 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
