This problem should be removed because:
Problem with Sony PlayStation 2 (PS2) Console
My disks won't spin or read on my ps2 slimline
My ps2 slimline turns on, goes to the browser screen, and does everything normally, except it doesn't spin or read any disks. What should I do?
Solutions (1)
hfgfhf
Suggested Solution (3)
check the following image with red marking area and if problem is not solved you better change the lens with a new one.
Source: wont spin
yes when you open your ps you can remove the lense by using small screw driver.
if you remove it you can blow very well by using air compresser
i need help too my ps2 wont work please help me! visit youtube you can see videos that show you how to clean your ps2. it should work if not please wirte back to me!
Source: disk on ps2 slimline won't spin
- Check to see if a Music cd will spin in the console
- Open flip lid and examine the reset switch - check to ensure the switch is intact - you are looking for a small lever which is made of lack plastic. If its not there you need a new reset switch
- If the laser is not moving at all you will need to open up the console (WILL OBVIOUSLY VOID YOU WARRANTY!)
- Check the PCB switch at the rear of the console. This part connects to the lid of the ps2 if thats is broken you will need to replace - difficult to source but they are available
- Check the ribbon cable underneath the PS2 Laser for any signs of damages
- Check the ribbon cables x 2 which attach the laser assembly to the motherboard
- Remove the motherboard metal shield and test the SMD (SURFACE MOUNTED) on the underside of the board use a multimeter for this
- If your console passes all these tests the most likely cause is a blown laser which is a simple part to source via ebay etc.
- If your new laser does not fix your problem then you have a blown RS2004 chip which is expensive to replace and usually not economical to do.
Source: disc not spinning browser/configuraion display on screen.
ps2 disk won't spin laser comes on goes out...
ps2 disk only spins quarter turn laser comes on goes off right away "no data" error
slimline ps2
my slim ps2 wont spin my metal gear solid disk. i tried cleanig it bt that didnt help...:( please help me
my ps2 was dropped by my lil brother
it turns on nd everything it even reads the disk but wen i go to the browser nd put the orb through the disk it acts like it is going to...
disk wont spin
i have a ps2 slim silver. i put a disk in and close the lid. i start it up and it goes straight to the browser screen. the disk just wont...
Add Your Solution
My ps2 asks for a playstation or Playstation2...
My ps2 asks for a playstation or Playstation2 configuration disk... this happened after erasing memory card. What is the...
my ps2 wont read disks of any kind
wont read disks. set it to dvd and put in a lens cleaner but it wont read it. what else can I do?
Related Topics
Fix-O-Meter
98
98 people viewed this problem
- 0 people are following this problem. Be the first!
Top Sony Video Game Console Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
