Question about HP Deskjet F4100 All-In-One InkJet Printer
Sometimes we cannot connect the printer, so sometimes it works perfectly and other times it doesn't work at all. Why? Our computer is Toshiba Dynabook with Vista Home Premium.
How to remove empty inkjet cartridge from HPF4100 printer
Posted on Sep 05, 2010
My epson perfection scanner doesn't work since i upgraded my iMac to OSX.10.8
Make sure you have installed the scanner drivers bcos sometimes it only installs printer drivers. I suggest you install the scanner drivers again. Make sure the scanner is turned in first b4 computer.
Oct 03, 2017 | Epson Perfection V700 PHOTO Flatbed...
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
I cant get the keyboard the respond to the hub, the mouse works fine but not athing from the keyboard. I have even put different batteries in.
I have this problem to sometimes. Hold the keyboard connect button with the hub connect button at the same time. If this doesn't work then restart the computer. If this does not work reinstall the software.
May 08, 2011 | Office Equipment & Supplies
My toshiba dynabook satellite 2140 says you need a disc to update your BIOS..what should i do?and my son accidentally sprinkled some water on the keyboard..is there a possibility to fix the problem or...
No, do not throw away. completely dry and try again. You can sometimes use a USB keyboard. REplacement keyboards for laptops are surpirisingly cheap, not counting install, but typically install is not serious, often no case opening...Toshiba, however, is sometimes a different story.....
A note about computers, Lower cost and seriously better stability are the reason to look at a new computer. Essentially, with an old machine, you put most of the cost of a new machine into repairs. but you still have an old machine....... Which will fail someday....
ALWAYS back up your data and All user files, like contact lists...E-mail addresses....
Oct 08, 2010 | Toshiba Computers & Internet
My toshiba laptop powers on all the time but sometimes there is no display or sometimes it powers on and there is display but all of a sudden i loose display and nothing works.
You have either a lose connection to the computer from the LCD or bad connection inside the laptop on the motherboard. I would remove the keyboard and reseat the cable on the motherboard. Go to Toshiba and download the service manual or go here http://www.eserviceinfo.com/equipment_mfg/Toshiba_43.html
If you are not technicaly inclined do not attempt to repair. Take to a repair shop. Toshiba laptop's are not fun to work on!!!!!!!!
Feb 20, 2010 | Computers & Internet
Video adapter driver
here is a link to download the driver for your Toshiba dynabook 1850 video adapter:
http://www.bioticaindia.com/download.php?file=dynabook-satellite-1850
Apr 24, 2009 | Computers & Internet
No LCD display at all on my Toshiba Dp80f fax
Once your open up the machine (like how u change toner kit),u will see a connector connected the LCD display to the base machine. Makesure the connector is firmly plugged.
May 29, 2008 | Toshiba DP80F Printer
Audio problem on toshiba dynabook 2550S
Have you tried reinstalling your drivers? Try connecting some external speakers to the headphone jack and see if it works? If it does the speakers on the laptop are gone, if not the sound card is indeed not working. Do you have a speaker icon in your system tray by the clock?
Jan 09, 2008 | Audio Players & Recorders
HP Deskjet F4100 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
