Question about LG Dryers
LG Tromm Dryer won't start - semiconductor sensor error
Hi - LG Tromm dryer DLE8377WM - ''start/pause'' button is flashing, all displays work fine, but dryer does not start when start is pressed. Did diagnostice, received ''semiconductor sensor error''. The Semi-conductor reading was 255, just before the the above error message was displayed.
I searched and could not find what this means. thanks in advance for any help, Steve.
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
rickzilla
  • 706 Answers
SOURCE: LG TROMM DRYER DLE2514W
Hello Napew65,
Please use this link http://136.166.4.200/contents/Laundry/DLE2514W.htm to get access to the service, operator and all manuals associated with your dryer. You can run diagnostics as shown in the service manual to interpret the root cause of your problem. Let me know if you still aren't able to get this resolved.
Regards
Rick
Posted on Jan 06, 2009
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
  • 1382 Answers
SOURCE: my frigidaire affinity dryer displays LOC
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Posted on Apr 16, 2010
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Posted on Jul 04, 2010
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
I am getting a lot of moisture inside my dryer. LG TROMM Model #:DLE8377WM
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 02, 2011 | LG Dryers
My LG DLE8377WM dryer stop spinning. Turns on fine, smells as though heater element turns on but the tub won't spin. Can hear what sounds like a motor trying to turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 25, 2011 | LG DLE8377 Dryer
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
May 20, 2010 | LG DLG5932W Gas Dryer
My lg tromm DLG3788W gas dryer is not heating, it says check filter. other wise it works fine. where is the filter at, i know the one where i open the door and clean the vent everytime i use it. thanks
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
Jul 30, 2009 | LG DLG5932W Gas Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Dryers Logo
844 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
