Question about Epson Stylus Color 760 InkJet Printer
Carriage cycles normally but no ink on paper.(Stylus color 880)
Printer unused for more than a month. Installed fresh cartridges--ran multiple cleaning cycles--no change. Utility screen indicates reduced ink levels (both cartridges) so I presume print heads gummed up from lack of use. Would I be capable off finding and flushing the print head plumbing???
  • Epson Master
  • 511 Answers
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Posted on Jun 28, 2009
How to read ink levels in an epson nx110
All Epson printers (well, the ink ones) have a small utility built-in called the STATUS MONITOR. If you click on the MAINTENANCE tabbed page in the Properties, you can start this just by clicking on the item. It will show the ink levels. Normally, this status monitor should start up whenever you print - with an option to show the ink levels, as they do not auto appear when printing, compared to the option shown above. Note that the monitor does NOT actually shown the real ink levels as the chips on the cartridges and the internal electronics within the printer simply work on the number of prints made - so often when showing empty - there will in fact be ink left unused inside the cartridges. For this reason alone, worth your while getting some refillable cartridges and bulk ink (normally in 100ml bottles - so you would get equivalent about 10+ refills and save lots of hard earned dosh!) but you would also need an inexpensive chip resetter. My advice is get the refillables with ink (most compatible inks are as good as - some better - than Epson's own expensive original cartridge inks) and when one cartridge shows requires replacing, you remove all the cartridges, fill them all, reset the chips and replace - that way you show all as full and on ly have one cleaning cycle - thus also saving lots of ink normally wasted when replacing one cartridge - each requiring a cleaning cycle and loss of other inks. I have no idea where in the World you live so cannot recommend a supplier - just use ebay.com or amazon.com to find suitable suppliers convenient to yourself.
May 29, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
Just purchased an Epson Stylus Pro 10000 Archival Ink. Nosel check looks good with solid lines, however prints are very light. Ran clean multiple times. Printer came with existing ink and I don't know if...
Old ink loses some of its intensity after about 8 months.
heat/light seems to destroy some of the depth in the ink's shade. i would be completely replacing the cartridges with fresh ones. Constant cleaning uses up so much ink and the casettes will need replacing too often. This raises the cost of your prints.
May 09, 2010 | Epson Stylus Pro 10000CF InkJet Printer
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Claims new ink cartridge is low...
Hello, at this point I would suggest COMPLETELY uninstall your photo printer, reboot your system and reinstall. Hopefully this helps.
I will tell you though, usually if after running cleaning utilities, the picture still has lines and spaces, could be due to print heads drying up and unable to output the proper amount of ink. This happens alot when people are not using their printer often enough to keep the ink flowing properly.
Recently I had to replace a printer that I had not printed on in like 3 months, the print heads dried up/ clogged up. And the new ink I had just purchased was a waste of money. Had to replace entire printer.
Feb 04, 2009 | Epson PictureMate Photo Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
Seem unable to get my ink cartridge holder in middle position to insert new cartridge. have tried 2 TR27 copy cartridges from ABITECH Nottingham but both made the error light flash ! Printer id EPSON...
I cannot remember if the Status Monitor (SM) of the 810 has a "change cartridge" facility, but it's easy to check. Right click the printer icon in the bottom right-hand corner of the screen and select printer settings. Then click the maintenance tab - is "change cartridge" one of the options? If so, use it. If it isn't you can download the SSC utility from
http://www.ssclg.com/epsone.shtml
and use this to move the cartridge to the cartridge change position - don't forget to use it to do an ink charge cycle after you have replaced the cartridge.
There is also the "generic" approach. Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move (gently!) by hand to the cartridge change position. The snag here is there is no inherent means of running an ink charge cycle - do a couple of head clean cycles instead.
Sep 15, 2008 | Epson Stylus Color 460 InkJet Printer
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
Epson Stylus Color 760 InkJet Printer Logo
262 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
