Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
I cant change the directionon the fan - Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
On the back of the remote by the battery are numbers 1-4. These are also on the fan. change the numbers to each fan
Posted on Jun 28, 2009
Radiator fans does not want to switch on and car is cutting out
i have forget my samsung sgh-c145 mobile password please help me sir
Apr 01, 2014 | Cars & Trucks
Cant change remote code
Don't forget you have to change the codes in BOTH the receiver & transmitter.
Nov 30, 2013 | Hunter Ceiling Fan Light Remote Control
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
Envoy cant get to water pump to change it. Removed grill exc but can't get radiator out and fan out
The fan and fan shroud need to be removed as one assembly. You will need a 34mm wrench to get the fan clutch removed from the water pump. Once the fan clutch is unthreaded and the bolts that hold the fan shroud to the radiator are removed you will be able to remove the fan clutch/ shroud assembly from the vehicle. You do not need to remove the radiator nor can you remove the radiator without first removing the clutch/shroud. You will notice that when you are removing it it will be a little tight getting around the inlet for the upper hose on the radiator . Once the shroud is removed trim a notch where the shroud was hitting on the inlet and I will make install a lot easier. If you have any questions let me know. Thank you for using fixya.com!
Oct 22, 2011 | 2004 GMC Envoy
How do you change direction? I cant find the switch. Remote?
Hi ,
The slide switch should be just above the light fifixture and below the fan blades. Good Luck !!!!!!!!
Jun 19, 2010 | Hampton Bay 52 In. 5-Blade Fan, Iron...
Enable java settings to use ebuddy on gt-s5233w Samsung phone
Can somebody please help me.
I am trying to log into ebuddy. I downloaded the software onto my Blackberry 8110 and then when I click the icon it says "Connection Failed" Your internet settings must be activated for Java Applications, or try again later. Check your phone manual or go to the website (unfortunately I cannot add the link) on how to do this. If this doesn't work you can always use our Lite Messenger".
Now I dont know how to activate Java Applications on my phone. I cant remember how to get to it either. Can someone please point me in the right directionon how to do this.
If I go to the Lite Messenger on the browser it works fine.
Thanks in advance for any help given.
s-m
Apr 20, 2010 | Samsung Cell Phones
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
81 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
