Question about Dewalt Plumbing
Hydraullic jack will not lower. Left rear does not lower when doing all extend most of the time and does not lower when using back rear control either.
  • texans39 Jun 30, 2009
    It is a Dewald hydraulif leveling system for my RV. It has a control panel to extend and retract the jacks to level the motor home. It has an "all extend" switch and it has a rear jack switch and two more switches to adjust the front and rear jack to get level. The "all extend" switch will not lower the left rear jack, but the switch that controls the left rear jack will lower it and then we can use the all other switches to get level.
    Scholar:
  • 89 Answers
WHAT KIND OF JACK IS THIS? WHY DOES IT HAVE A BACK REAR CONTROLLER. ARE YOU TALKING ABOUT A VEHICLE LIFT? JODY
Posted on Jun 29, 2009
Where to use a hydraulic jack on 99 intrepid frame
Place jack only under lower control arms front and rear. GOOD LUCK FRIEND.
Nov 23, 2014 | Cars & Trucks
Im looking for an owners manual for my RV Leveling jacks. I have 1991 American Eagle Diesel Pusher all I know is there are 4 hydraulic fluid leveling jacks
Like any number of items on motorhomes the builder will use what's available at the time; there is no one make of leveling jacks that they used on that coach. However you should be about to contact a Fleetwood dealer and see is they might have a lead for them. American Eagle are the high end coaches by Fleetwood. What is it you're trying to do with your jacks? The jacks themselves are pretty basic; they're like a number of other hydraulic cylinders in the principals of how they operate. There are times that if you look for generic hydraulic parts they are cheaper, or better quality (or lower depending on the original build).
Nov 07, 2014 | Cars & Trucks
Motomaster motorcycle jack won't raise
Hi Bogdan:
Seems there may be some confusing instructions.
Here's what I would try. My approach would be intended to get the bike off the stand before I tried to trouble shoot the motomaster jack.
1) Use the handle to rotate the release valve to the right (clockwise) until it is snug.
2) Pump the jack to try to raise it. If it raises, then press the release pedal and use the jack handle to slowly rotate the release valve to the left (counter-clockwise) to lower the deck.
3) If it does not raise, I would use a separate jack to raise it, then follow the prescribed lowering procedure, and at the same time, use the control on the extra jack to manage the lowering.
Once you get it partially lowered, hopefully the motomaster jack will start to function and you can lift the bike far enough to remove your extra jack.
Hope this helps.
To let me know if it works for you, please reply as a comment to this post..
Jul 29, 2013 | Motormaster Cv Joint Front Female*-ATV
Where Do I Fill Oil Into My Car Jack?
Usually only oil has to be added if the jack will not pump up, not down. They go down either by added retraction springs or by the weight of what they were lifting.
Anyway, look for a small rubber plug about 1/2" in diameter on the hydraulic unit, lay the unit on it's side so when the rubber plug is removed the oil won't run out. Once you remove the plug, fill it up with hydraulic jack oil from an auto parts store. Put the plug back in, you may have to work the jack to purge air bubbles, by pumping it up and down a few times.
May 05, 2010 | Sander Industrial Original Clarke Floor...
1995 n pug 306 td. how to change back axle mounts.
remove the rear box off the exhaust(2x13mm nuts)prop the front wheels then jack the back end of the car up put the jack on the tube of the axle use 2x axle stands on the rear jacking points on the sills lower the car on to the stands(leav the jack under the rear axle to help lower it to the ground) then release the hand brake.now in side the boot of the car you will find 3x16mm nuts on the left side and the same on the drivers side there are some times plastic gromits covering the nuts undo the nuts and lower the jack wala the axle is off.DO NOT FORGET TO UNDO THE BRAKE PIPES.the rest is simple.i have done this job by my self many times.
Jul 07, 2009 | 1991 Peugeot 405
1995 bmw 525i
Very common BMW problem. The front lateral arms that support the front to rear motion of the wheel. BMW calls it the upper, lower support arm. Two arms connect there. one left to right (think typical lower control arm, and this arm) It has a ball joint that connects to the lower most part of the strut and extends rearward to the rear crossmember and has a large bushing pressed into the arm. You can replace just the bushing if the ball joint end is ok. Bushings are about $45 each and you will need a press.
Feb 18, 2009 | 1995 BMW 5 Series
Hydraulic jack will not lower
hs it been overfilled? I sugest removin all the oil. lowering the jack, then re-filling withoil with the jack in the closed possition.
Feb 12, 2009 | RTO 20 Ton Air / Hydraulic Bottle Jack
Plumbing Logo
59 people viewed this question
Top Dewalt Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Dewalt Plumbing Expert? Answer questions, earn points and help others
