Question about Kenmore 64802 Top Freezer Refrigerator
Water drains inside the ref when the defrost cycle start
    Sergeant:
  • 163 Answers
The water is supposed to drain from the catch pan under the freezer coil that is defrosting, to a catch pan under the refrigerator. There is a hose connecting the two pans. This hose is stopped up with a common slimy growth and needs a wire or ideally a brush on a flexible cable run up inside it to clear the problem.
Posted on Jun 28, 2009
Why does water drip inside the ref toward tne rear of the ref? Happens once a day
That's the automatic defrost cycling. The water collects at the bottom and drains into a flat pan underneath for eventual evaporation.
Jul 19, 2014 | Hotpoint Refrigerators
Water dripping inside the refrigerator and freezes all foods inside.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Oct 03, 2011 | Whirlpool ET1FTKXK Top Freezer...
Water is always laying on shelves and under vegetable drawers, drain pan is dry, has ice maker, but we do not have it hooked up. This is located in our basement in a pantry.
That water is coming from the defrost cycle ..their is a drain that usually drains that water into a pan in the bottom of the ref.but that drain is blocked so the water is dripping inside from the vents in the ceiling of the refrig.
This tip i wrote will help ya to clear that blocked drain.
http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 25, 2011 | Refrigerators
My model FRT18B4AW4 refrigerator leaks water into the bottom underneath the bottom trays and onto onto the floor about once every 2 weeks (no ice maker). Temperatures are OK inside. I guess that the drain...
Leo Ponder
imufo2
Sep 10, 2011 | Frigidaire Refrigerators
Water is leaking in fridge down the back wall i and from the light bulb socket when in defrost cycle its a (ge fridge)
Leo Ponder
imufo2
Sep 04, 2011 | Refrigerators
Water leaking out of the freezer door.I believe from clogged drain from defrost cycle.. I have had the water shut off for a while due to a problem with the ice maker so that is not the cause. looking for a...
Leo Ponder
imufo2
Aug 24, 2011 | Jenn-Air Refrigerators
Why is water leaking inside the refrigerator. found water in back on all levels.
You probably have a frozen drain if its a top freezer. The water from the defrost cycle will drip down into the ref section. The easiest fix would be to shut the unit down for 24 hrs with the doors open. The other option would be removing the back panel and using a turkey baster shooting hot water down the drain line until it thaws. Good luck _MJ_
Mar 09, 2010 | Whirlpool Refrigerators
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GDS20SBSBSS FREEZER DRAWER WON'T OPEN
ice will most likely form again.you have a defrost problem.most likely it is your defrost heater.their are a few things that control your defrost cycle.defrost timer,thermostat and defrost heater.most of your newer ref. will also have a control board on the back of ref. or under ref in a usually grey box.but check your heaters first.you will need to take the back panel off in freezer.you will see heater at the bottom of coils.if you have a set of meters you can check for continuity to heater.also your drain below heater sounds clogged.i usually steam out drain but you can use hot water.water should go down drainwhen unclogged.that will prevent the drawer from sticking.
Jan 26, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Every few days a stream of water comes out
The defrost heater is working, but the drain is blocked with ice. Every time the ref. goes into defrost the water does not drain down to the pan underneath the ref. You will need to remove the inside back cover in freezer and remove all the ice that has built up. you will need to defrost the ice with boiling water until the drain opens. then you will need to attach a heat probe to the heater and down into the drain. Usually you can use a piece of copper or aluminum wire to attach to the heater.
Dec 14, 2008 | Jenn-Air JCB2389G Stainless Steel Side by...
Kenmore 64802 Top Freezer Refrigerator Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
