Question about Gateway M-6867 PC Notebook
Media Panel problems in M-6867 Gateway model
The buttons from the media panel on the M-6867 Gateway Model that launch Media Center (default), Music and DVD player do not work. I noticed the problem when the OS (VISTA 64) of my laptop got magically erased.The buttons of play thru mute work properly. I do not know where the media panel settings are. Thanks for the help!
  • barts179 Jun 28, 2009
    I checked at the gateway webpage and doesn't have any driver for the media panel.
  • 1,800 Answers
There is like an driver or software shud be installeed so the buttonswould work perfectly.
Posted on Jun 28, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Windows media player won't play any audio selections , says can't find files
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
Download to ipod
How Do I Download Songs Onto My iPod Nano?
IPod Nanos are portable multimedia players that allow you to playback songs and other content (e.g. video) no matter where you go. They come in a variety of memory sizes such as 4GB or 16GB (gigabytes) and work with iTunes to upload songs. ITunes is the iPod default management program which allows you to upload songs to its library, create playlists and sync music on your iPod quickly and easily. This simple process will have you jamming to your favorite songs in no time.
Downloading to an iPod Nano1Connect your iPod Nano to the computer using the USB cable. Launch iTunes if does not automatically launch. When you launch iTunes, it will display your iPod Nano on the left panel.
2Add music to your iTunes library. Click the "File" button on the top menu and click "Add to Library." Locate the song you want to upload to your player and click "Open" to load it to your program.
3Click the "+" button on the lower left panel to create a playlist. Type a name for the playlist and drag the uploaded file to it. To upload additional songs, repeat Step 2 and drag the uploaded additional songs to the created playlist.
4Drag the songs in the playlist up or down to select the order in which the songs will play.
5Sync your iPod Nano. Click the iPod icon on the left panel after importing songs and adding them to the created playlist. Click the "Music" tab and click "Sync music." Click "Select playlists, artists and genres" and select the playlist you created that contains the songs you want to upload. Click "Apply" to automatically sync and download the songs to your iPod Nano.
6Click the "Eject" button and disconnect your iPod from the computer.
Tips & Warnings
Click "Music Store" if you want to purchase a music file. Search for the song on the iTunes store and download it to the iTunes library.
Nov 23, 2011 | Apple iPod nano
I can not copy an audio CD into my computer!
You can't copy Audio CD's to a hard drive. The .cda format is meant for only CD's. You have to rip them to some other format for a hard drive to recognize (such as .wma or .mp3).
How to rip an Audio CD using Windows Media Player
QUICK RIP
You can do a quick rip if the "AutoPlay" menu comes out when you insert a disk in your computer's DVD/CD drive.
One of the options under AutoPlay is to "Rip Music From CD (using Windows Media Player)" which will automatically launch Windows Media Player and the Rip menu. Make sure you uncheck the "Always do this for Audio CDs" box so your computer doesn't automatically launch the Rip menu every time you insert a CD (i.e. in case you just want to listen to a CD next time).
Start the ripping process by clicking on the "Start Rip" button (e.g. in Windows Media Player 11, for example, it's on the lower right once you're in the Rip menu). You'll also have an option to use your Internet connection and have Windows Media Player automatically find details about the CD you're using so you don't have to fill out album and song details yourself (for this tutorial, let's assume that you're not connected to the Internet, which means you'll end up with an unknown album with unknown songs). You'll know the ripping process is done once all the songs show "Ripped to library" under "Rip status."
By default, Windows Media Player will rip your tunes in WMA format and save it in your "Music" folder. You can access the folder by clicking on the Windows logo at the bottom left of your computer's screen. For Windows XP, for example, it'll be the "Start" button. For Windows Vista or Windows 7, it's the circular icon with the Windows four-panel graphic that looks like a waving flag.
Clicking the "Start" button in Windows XP will bring up a menu box with "My Music" as one of the options. For Vista, clicking on the Windows button will bring up a menu with "Music" as one of your options. Anyway, clicking on either of those choices will open your music folder. Look under Unknown Artist and you should be able to find the Unknown Album you just ripped. Once you find the songs, you can rename them one by one.
To do a normal rip, let's go to the next step.
NORMAL RIP
For more options, like changing your ripped music's format to MP3 or changing the folder where you save your music, you can do a normal rip.
Start by launching Windows Media Player yourself via the "Programs" option by clicking on either the "Start Menu" tab in Windows XP or the Windows logo in Vista or Windows 7 (both at the lower left of your screen). Insert your music CD. (To simplify things, just cancel and close down the "Autoplay" menu in case it shows up.)
Once you're in the Rip menu, click on the Rip tab to bring up a list of options. "Format" lets you pick between Windows Media Audio formats, WAV, and the more popular MP3 format. The WMA and WAV both have "lossless" format options, which means the music will be ripped with no loss in quality. The MP3 format, meanwhile, offers wider compatibility with portable music players and smaller file sizes but sacrifices a certain amount of quality depending on the bit rate of your file. This brings us to the "Bit Rate" button, which basically lets you pick the quality of the rip. The default for bit rate is 128 Kbps. Note that the higher the bit rate you pick, the better the quality you'll get, but you'll also get a larger file size.
========this worked for me and should work for you too, please let me know if it helps========
Jun 20, 2011 | Navarre 123 Copy Dvd Gold for PC
Windows media center has taken over under one sign in almost every program
I believe the media center has been configured as your default application to launch your programs. You could click on start button and got to default programs. from there click on auto play settings. you'll have an option there to select w/c software you want to use or run.
Good luck
Ryan
Jan 09, 2011 | Toshiba Satellite L455DS5976
How do i turn on the media center buttons?
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK. For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
Hope this helps.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen
Feb 10, 2010 | Gateway M-6866 15.4" Widescreen Laptop...
Tuner Not Found when launching Media Center
Try going into uninstall programs and find media center.
Highlight media center and click on repair.
See if this helps.
Your might also look in your device manager thats located in your control panel and see if there are any problems there.
May 20, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
How doi get the files to go to my windos media player library?
GO TO THE FILE WERE YOUR E-MUSIC IS DOWN LOADED TO AND EACH SONG AND LAUNCH IT FROM THERE MAKE SURE YOUR WINDOWS MEDIA PLAYER IS SET AS YOUR DEFAULT PLAYER YOU CAN DO THAT BY RIGHT CLICKING ON EACH SONG AND CHECKING IT AFTER YOU LAUNCH THE SONG FROM THERE IT SHOULD PUT THAT SONG IN YOUR WMP LIBRARY AND ALSO USE WMP TO PLAY THE SONG YOU DONT HAVE TO PLAY THE FULL SONG JUST THE BEGINING OF IT,IF THAT DOES'NT WORK THEN CHECK YOUR WMP SETTING TO MAKE SURE THAT THE SONGS THAT YOU LAUNCH WITH WMP ARE AUTO ADDED TO YOUR LIBRARY
Mar 14, 2009 | Audio Players & Recorders
My cineDash media console has stopped working
Confirm that this solution work very well. Thank you.
Jul 07, 2008 | Audio Players & Recorders
Function Button issues
if you have programmable keyboard media buttons, then there should be an ACER windows utility that allows you to set the feature for each button. if not installed, then go to ACER website and search for your model then available system utilities
May 25, 2007 | Acer Aspire 3000 Notebook
Gateway M-6867 PC Notebook Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
