Magellan Roadmate 1200 Car GPS Receiver Logo
Posted on Jun 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The unit began freezes upon boot up (at half way of blue status bar), I reset HDD, now freezes with no progress at status bar. USB connection not recognized by win XP.
Anonymous
Level 3:
President:
  • Master 1,111 Answers
  • Posted on Jun 28, 2009
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
381011
Points
3221
Try the update if you havent already.
go here to download your update, you must register it on magellan before they will let you down load...follow the directions to the letter or youll have a new paper weight
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
1helpful
2answers
SYSTEM PROBLEM FOUND
You need to update the toy. Connect it to your Learning Lodge Navigator. You should be prompted for an update.
Hp xw4600 BIOS issues
I have one too love mine, its now a server.
the Z400 or z600 are even more cool,l best of the best.
so did you just find these Enterprise workstation, its not a PC.
its a work station, Ill explain it .
this WS if reset or out of the box new boots to thin net.
that means it boots from another server using the built in ethernet chip, PXE. and will not boot to hdd. by default , OOBE
learn to use BIOS, the book on this great workstation covers that.
you must turn off PXE first the set the boot order any way you wish. HDD, CD, USB drives, SD mem, and PXE (no dont)
is the coin cell RTC new and fresh, most dont last this long
and is job 1, after about 7 years old. (5 lowest)
mine can boot to linux ubuntu 16 on USB stick or CD or DVD
a fact
and mine runs windows 10 64bit fast.
I even run a p410 HP RAID card and huge array. in it no issues
here is a page that shows lots of 4500 tricks and secrets
http://pcdied.com/intel-magic/xw4600.html
see bios photo NIC PXE , see DO THIS.
Unit freezes at the loading maps stage
Yes! Yes! The exact same thing is happening to my nuvi 1300 right now one month after yours. What did you figure out? Can someone help? I've also tried to do the clear the device by pushing the right hand corner of the screen while powering on and I do not get any sort of 'would you like to clear everything?' message that I'm suppose to get. I'm going to check into battery recall that I heard about, but I don't think it's for the Nuvi 1300. Someone help! A :)
Jul 26, 2010 • Garmin GPS
17helpful
3answers
Garmin 1390t freezes at loading maps
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Freezing in 'safe mode'
Have you tried accessing the bios to set boot order? It may be trying to load from the hdd before the optical/usb drive.
During the flash screen, press F2 (though it can vary by maker) and change your boot order to load the USB drive first.
Hope this helps!
Drive "died"
you can get "live" versions .... mandarin is pretty good
3answers
HP 3055 AIO prevents boot-up / causes lock-ups in Win2000
REPLACE IN THIS ORDER.
CABEL(CHEAPEST)
IF THAT DOES NOT WORK
IT NEEDS A FORMATTER BOARD.
HP 3055 prevents boot up in Win2000, causes lockup when connected
Actually I deleted the PCL 6 drivers which had been installed by the original HP driver CD, went to the HP website and downloaded the PCL 5e drivers instead.
I also added a USB switchbox between the PC and Printer, leaving the default setting as disconnected. Now, it boots up fine, without having the HP printer connected.
In use, I wait until just before I need to print a document, switch the USB selector to connected and obtain hardcopies of my documents.
Then, to ensure against screen lockups / freezing, I switch the USB selector back to disconnected.
It's a kludge and not what you should have to do for a $400 laser printer AIO device.
Naturally, I am completely unimpressed with HP software engineers, who have a functionality somewhat below Dilbert and his crew.
Toshiba A60 Not Booting
You might want to run a harddrive diagnostic test. You can find bootable iso's on the harddrive manufacturers website.
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
