Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Why Hotpoint WF000 flashing rinse hold light - Hotpoint Aquarius WD63 Front Load Washer/Dryer
SOURCE:
  • 1294 Answers
SOURCE: belt fitting for a WF000 hotpoint washer?
It should go around 2 wheels; one is the pulley of the motor, where there is a good groove. The other goes around the tub wheel which is big one. First fit to the motor wheel then fit to one side of this big wheel & turn the wheel to engage it gently. The belt should have a "give" of only half an inch, or it will be too loose or too tight.
If helped pl rate.........
Posted on Dec 28, 2007
Richie_asg1
  • 1036 Answers
SOURCE: Hotpoint Aquarius WD440, Rinse Hold, Time Saver and On/Off light flashing
This is typical of a control board problem.
About 60% of the time they can be repaired, but it's easier to replace it than keep testing.
If you are competent at electrical repairs, then read -on, otherwise order a replacement, and have it fitted.
Isolate supply.
Remove top cover by removing screws at top rear, slide cover rearwards.
Control board is on right at the front.
Test connections - remove and replace all connections, checking for signs of arcing.
Check main wiring loom to motor for integrity and damage.
If no signs of damage, remove control unit board, and examine for arcing or poor contacts, overheated components or damage.
If everything still looks ok, a replacement control board should be fitted and the machine tested.
Hope this helps.
Posted on Jun 11, 2008
SOURCE: Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Posted on Jan 22, 2009
  • 1294 Answers
SOURCE: need to clean fillter on hotpoint wf000
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too.
Posted on Mar 21, 2009
ginko
  • 19396 Answers
SOURCE: hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 16, 2009
Error codes On/off rinse hold & TIME SAVER LIGHTS FLASHING
For error codes and what they mean go to www.selfix-uk.co.uk
Jul 21, 2011 | Hotpoint Aquarius WF000 Front Load Washer
On/off rinse hold & TIME SAVER LIGHTS FLASHING WON'T DO CYCLE
For error code definitions on Hotpoint, Creda and Indesit machines use this link
Mar 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Flashing lights
Sounds like a fault code Ring your local dealer They should have a list of codes and what they mean Hopefully they'll be kind enough to tell you over phone
Oct 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Display lights flash
I have just posted the same problem about the lights flashing rapidly, I have just gone to investigate my machine and switched it off and on again at the mains and so far it has resolved the problem. Hope this works for you.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Flashing power light and rinse hold light
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Extra rinse light flashes
make sure none of the option buttons are stuck in if on is simply run a pin round the outer edge to release it
Sep 16, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
59 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
