Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Problem for Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing machine out of balance.
By greg_stuck on Jun 28, 2009
It has been leveled and still walks across the floor in the spin cycle. One answer on this forum was that the sump was blocked. What does that mean and how can I fix it?
Best Solution
posted on Jun 28, 2009
Very Helpful)
SolutionGuy
Rank: Guru  Whirlpool Expert
Rating: 95%, 647 votes
Hi Greg,
The symptom you described tells me that the "shoes" have gone to appliance parts heaven and need to be replaced. Trust me, the "sump" is most definitely NOT to blame... top loaders don't even HAVE a sump!
First you'll have to do a little homework... Start by clicking here and look at part number 18 (there are 3 separate pieces and come as a set). The part number is 285744. You can get them from a local appliance parts outfit or order them online <---just type the part number into your favorite search engine. You'll also notice that the shoes are inside the cabinet, that means the cabinet will have to be removed to get to 'em. OK... just watch this video to learn how to do that.
ALWAYS UNPLUG THE WASHER PRIOR TO SERVICING IT!
After you have the parts, you'll notice they have little "pegs" on them. These pegs snap into the pedestal (refer back to the link above). That means your old ones have be snapped OUT, right? Here's the way I do it...
(Assuming you have the cabinet removed) Start at one of the 3 pedestal supports and do one at a time. Use a large screwdriver and pry the 2 plates apart, then I use a hammer handle (because I carry hammers with me and they're handy) and insert it between the 2 plates to keep 'em separated. Now from under the pedestal, tap the pegs of the old shoes to pop them out. Now take one of your new parts and simply place the pegs into the holes. (NOTE!!! Don't try snapping it in right now, 'cause you'll break it!) Now that the shoe is in place (and not snapped in) just remove the hammer handle and allow the upper plate to drop down onto the newly installed shoe. (You'll snap all of them into place at the end of all this, OK?) Now do the same thing with the other 2 shoes.
OK, now that all 3 shoes are in, you'll now snap them into place. Do this by standing in front of the washer above one of the pedestal legs. Place both hands on top of the plastic tub and with a quick, forceful motion push sharply down. You'll here the shoe snap in. Do this on all 3 corners. (TECH NOTE---> Doing it this way ensures that pressure is evenly applied across the entire top of the new shoes preventing them from breaking) After that's done, grab a flashlight and look under the pedestal at each of the shoes to inspect and ensure that the pegs fully seated, if not... repeat the "push down" technique until all pegs are fully seated.
All that's left now is to rebuild the washer! I know it sounds like a tough job, but if you have all your tools ready and all goes well... you're looking at about 45 minutes.
Don't forget to rate this solution, OK?
SG
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Whirlpool Ultimate Care II
Questions and Unsolved Problems for Whirlpool Ultimate Care II
Do you recommend Whirlpool Ultimate Care II LSQ9564J Top Load Washer?
Answer
Answer
loud noise during spin won't spin but drains water whirlpool ultimate care ii. need instructions on... (More)
Answer
tub is full of water and will not drain out ,the agitator works but that is all.
Answer
the washer will not go to spin after wash it fills but will not signal to spin If you skip to the... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
