Question about Hoover F5835900 Upright Steam Vacuum
Not pulling water up. let out but seems to be blowing out and not pulling up water
  • 174 Answers
Hello
Click HERE to get the manual. Go to figure 3.1 and clean the filter if necessary. Go to figure 3.8 and make sure pate E is clear. Make sure the part is slides up against when inserted downward is clear. Go to figure 3.11. The slotted holes in the recovery tank lid must be clear. Finally the recovery tank tank must fit snugly and air tight. I hope this works
Posted on Jun 28, 2009
Water want come out
Clean sand granules out of the motor! the problem appears to be sand granules from the sand filter jamming the "pulse motor", unplug take the water cart off, unscrew the back cover, the one with the label (6 crosspoint screws) beware the 2 long ones holding the end! inside the cover there is a small bulge, next the pipe,, unscrew 3 screws these it reveals the motor squeeze the pipe clip slide back pull forward, to release motor blow through,the tiny hole backwards, until clear, you may have to use a blunt toothpick! to release, the stuck granules...Blow, blow, then reassemble
Jan 01, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do I clean Hitachi Tower Fan Model CF26PH? There doesn't seem to be a manual online in English and it's filthy inside. Can I just pull off the grill?
The easiest way is to take an air compressor and blow out the dust internally first through all of the vents. Then just take a damp cloth with a water/soap mix or some cleaning product that can be used on the plastic and just wipe down the outside. I recommend using the air compressor outside. If you don't have an air compressor available to you, then the cans of compressed air will work too.
Let me know how this works out for you.
Benjamin
May 23, 2010 | Hitachi Vacuums
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
Confirm that the hose is correctly connected to the clean water supply. If so, then remove it and, with the trigger operated on the hose, try to blow into the water feed connector. If you cannot pass air, the feed tube in the hose is clogged and must be cleaned (either by running faucet water into the brush end (with trigger pulled) or by using compressed air....
Nov 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover f5835-900 will not pick up water. seems to be blowing air
Hello
Click HERE toget the manual. Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Jun 28, 2009 | Hoover F5835900 Upright Steam Vacuum
No solution or water coming out...
the water out let are pluged the machine sits dormant with soap in gravity pulls it down and the heat drys it. thus on h2o now to fix it turn up side down remove screws from bottem plate and belt assembly turn back over lay handle on floor remove scews from middle front and back use long blade screw driver remove cover with cellphone take pic of vac with cover off [ for reference on reassembly] water head located on the front of vac pull head and hose from seat wash with hottest water you can stand try to blow air through it with your mouth .with cover off put water tank in plug in vac careful not **** any thing up turn on vac try the water if no try pump check hose connector. To reassemble reverse steps using pic as refenece this should help later
Apr 01, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
I can't get my shark steam blaster model EP95 to create steam?
pull the (3) coasters/feet out and unscrew the 3 screws. take off the one end of the steam"boiler" (two clamps). tilt open end up and pour white vinegar [carefully] in there, prop up so it does not fall over, and soak overnight. dump out lime and water scale and rinse out a couple of times. Be very careful to not get water on electrical parts.
Take an air pig and blow out the line (Black) from where you disattached it to where the steam comes out [at the handle]. Be sure to mark electrical connections [4 on one, 2 on the other] so you don't blow a breaker switch like I did.
Oct 26, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
No Suction
It should **** back up the water as you move along.
It seems like you have a suction leak or it is plugged with debris.
I would take it apart and clean.
Mar 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Craftsman 20 Gal Wet/Dry Vacuum model number 17762
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Feb 13, 2008 | Craftsman 17762 Wet/Dry Vacuum
Hoover F5835900 Upright Steam Vacuum Logo
255 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
