Question about HP LaserJet 1000 Printer
HP Laserjet 1000
I have this printer and what is happening is that when I plug in the printer it starts to feed the paper and the it stops. When I send a test page to print it just feeds the papers and prints nothing. There is nothing wrong with the toner and it was printing ok before this problem. I get to understand that it can be a sensor problem but I don't know where or what to look for. Thanks in advance for your help.
  • 1 more comment
  • tntfix Nov 09, 2007
    i have problem with my hp laserjet1000,
    if i print a document, the paper see like dark..kind a toner...
    what can i don with my printing device
    thanks 4 help me
  • zekester Dec 21, 2007
    when i send a print job, the printer tries to print but can't pick up the paper. i have opened the printer and cleaned it, checking for any debris that be obstucting.
  • mstammii Aug 15, 2008
    the paper tray pick up multiple paper, and it normal pick up the paper one (1) at a time now it pick up the paper rapidly, what can i do to resolve this problem
    Problem Solver:
  • 18 Answers
There is one plastick stick on the cartridge opener cover(front cover) actually it hits the scanner sensor.the the scanner became on. so inspect it .may be it broke.
Posted on Feb 20, 2008
  • 82 Answers
Maybe some problem with pick-up clutch inside right cover, or the U-shaped pick up roller rod is twisted...
Posted on Dec 28, 2007
False paper jam hp laserjet 4200
Do you have this problem if you try to feed the paper from the manual paper tray? Does this happen all the time or only once in a while? It may be that the paper feed rollers are slipping and this is throwing off the timing of the printer and it stops because it does not know where the paper is. If the printer will feed fine from manual then check the rollers in the tray 2 cavity. The white cored roller is the pickup roller and the blue cored roller is the feed roller. Clean both with a paper towel dampened with water. Post back what you find and I can assist further.Also make sure that the paper guides in the tray are set properly. The back stop on these trays has a habit of either sliding back or cracking.
Sep 02, 2014 | HP LaserJet 4200 Printer
HP LaserJet 1012: The paper has stopped feeding. I hear the feeding mechanism rolling, but the paper does not feed.
Check the adjustment of the guides in the paper tray. There should be about an 1/8 inch of play from front to back so that the sheets of paper so they can be lifted from the tray. If the stack of paper is snug, move the rear guide back a little bit.
Feb 27, 2011 | HP LaserJet 1012 Printer
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
HP Laserjet 2200d -- Paper won't feed through
Remove the paper cassette and the toner. Turn the printer upside down and look at the feed roller.
It should NOT spin freely, drive tabs may be broken off of the roller shaft.
Jan 23, 2009 | HP LaserJet 2200dn Printer
HP LaserJet 5000n - Paper jam under the cartridge
Check the tray to make sure the paper stops are set right and that the printer is set for the correct size paper. Clean the feed rollers above the paper in the tray and if necessary, replace them.
Jan 03, 2009 | HP LaserJet 5000n Printer
Paper feed
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Dec 21, 2007 | HP LaserJet 1000 Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
122 people viewed this question
Ben Johnson
