Question about Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL is spitting dust out of the housing when it runs. There is a crack in the plastic intake that connects to the motor. Can this be fixed or replaced?
    New Friend:
I have a model XL2450RH and it has been blowing dust out of the joint in the back is this the same issue???
My Oreck XL is spitting dust out of the housing - 1_5_2013_7_15_20_pm.jpg1_5_2013_7_15_34_pm.jpg
Posted on Jan 05, 2013
  • 357 Answers
I, too have Oreck XL that kicks off the belt
Thomas,
Check where the bearings mount in the housing and see if they are tight. If they move back and forth in the housing mounts, that could cause the brush to shift and cause the belt to come off. Which model XL do you have? Some of the models have extended warranty and you might have the possibility of having it covered.
May 25, 2015 | Oreck Vacuums
Replace a motor
You can find a replacement motor:
Replacement Oreck Vacuum Cleaner Motor , you may have a plastic housing that snaps together and may be stuck due to years of use and dirt.
800-775-6586
GoodVac com
Apr 06, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl 21 fan housing has new design. willit stillfit my older vac
It should. You can call Oreck and talk with them and give them the serial number off your vacuum and they can look it up and tell you for sure if it will fit or not.
Feb 18, 2013 | Oreck Great XL21 XL 21 8 Pound Upright...
Dirty Oreck bag
yes but separately from other clothes
Aug 09, 2009 | Oreck XL Ultra Bagged Upright Vacuum
I had a loose wire in my Oreck XL motor. I took it
Lights are 12 volts.
The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
Aug 07, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Model Oreck 2600HH- need schematic
white to motor terminal,black to other motor terminal,green is always ground to housing there is a small terminal tucked away its s small spot for the lights
Feb 01, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Leaks Dirt At Bag Entrance
do you use a docking station to put your bag on or is it just a push on bag? also when you turn on the vac with an empty bag in it, does the outter bag blow up?
Dec 18, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
Wiring schematic oreck xl2600hh
I have a Oreck XL and the propeller that is in the housing will become hard for the moter to turn. I have took it apart and do not see a problem, but when I reinstall the parts it will run for about 15 sec. and the moter will stop turning. When the propeller housing is off the motor turns ok and doesn't stop. Do I need a new propeller/housing?
Nov 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Jun 07, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
833 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
