Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman lt 1000 wont stay running
Craftsman lt 1000 briggs and stratton 18hp intek wont stay running at full throttle with blades engaged ive put a new plug in, new fuel filter, new gas, oil change, new air filter and took the carb off and cleaned it even put a new battery in just cause but still nothing im at a complete loss what to do now except go buy a new mower (thats not craftsman) so if anyone could help i would be extremely greatful
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
    Habit-Forming:
    Scholar:
  • 54 Answers
You have a fuel governor problem. This governor works the carburetor allowing the right amount of fuel. When the mower comes under a load the governor opens up allowing more fuel to the carburetor. If the governor is bad or it is out of adjustment (adjustments can be made using a screwdriver). You might say that when,the governor fails to supply fuel correctly,there isn't fuel enough to operate the motor to carry the extra load,the motor has to speed up,if not,it will die from fuel starvation. It will start right up if the mower is disengaged and probably will idle alright and the tractor will move,but not under a heavy load condition. This adjustment should have been done at the factory. A full throttle condition,doesn't always mean that the mower can carry a heavy load condition,without the governor operating correctly.Hope this helps,i can't really tell if it's the governor,is the culprit without actually hearing the governor kick in. Sincerely,Brad Locke
Posted on Oct 15, 2015
  • 513 Answers
Does it run fine with-out the blades on if yes & it acts up when the blades are on there is a safty switch under seat that might be bad the blades wont engage or operate without the switch being pushed in if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a 18HP B&S Vangaurd Vertical shaft on a scag walkbehind motor runs good untill I engage the blades then it seems to draw down to about half throttle until I disengage the blades then the motor...
Check the govenor spring to see that it is not stretched out or popped off...there should be a colored spring on the throttle plate where the throttle lever connects to...also, there are several holes in the plate where the spring attaches...these hole will set the sensitivity of the govenor...you may need to make it more sensitive to hold the engine speed high when engaging the blades
May 11, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
18hp B&S wont slow down no matter where
It's one of two things. Most likely, the screw(s) have come out of the butterfly valve on the throttle shaft and letting it run wide open. The second thing is that the governor gear inside the engine broke. Unless you a pretty good mechanic, I'd recommend taking it to a shop. If it is just the butterfly in the carb, you still have to deal with...where did the screws go? They may have passed through the intake and exhaust valves or they may be stuck in one of the valve seats or embedded in the piston. Like I said, better take it to a trusted shop, if there is such a thing, unless you live close to me. lol.
Jun 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,439 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
