Question about Dell Inspiron 1100 Notebook
Error loading operating system
Ok, so I wanted to wipe out my hard drive but didnt have a Windows XP installation disk, so I used killdisk. After I burned killdisk onto a cd I stuck it into my computer and restarted like it told me, and it went through the wipe out process and after it was done it said restart. So, I restarted my computer and it shows the blue Dell at first then it turns to a black screen and says Error loading Operating system. I have tried getting into setup, Bios and everything but its not letting me, it keeps going back to the same screen with the error. BTW, after I wiped out my system with killdisk, my brother finally broght over the installation disk, but, even after putting it into the dvdrom, it still doesnt do anything. Please help me!
  • 20 more comments
  • cbeverly2009 Jun 28, 2009
    I understand that but it wont even let me into Bios, or setup or nothing. I have pushed f12, f3, all of them and it still not working. It keeps going to the black screen with the error message.
    My Dell is a Laptop. First off, I did mention that info in the Original post. What do you mean does my keyboard light up? No, it doesnt light up.
    Ok, did it and nothing happened, besides it going back to the black screen with error
    Ok, so I dont have a usb keyboard, sorry, but, my keyboard on my computer reacts to me pushing buttons, it has a loud beep when I push a button. I am not sure how to take out the hard drive
    Yeah I tried that one first, but still no help.
    ok be back in a few
    Ok, so it went to Windows setup and started loading files. I turned it off and put the hard drive back in.
    Ok, I tried f2 again but the same thing happened, so I took out the installation disk and removed the hard drive again and when I pushed f2 it came up and said operating system not found.
    I dont have a usb keyboard but I found one that has a video-s kind of hook up.
    I did tap it. umm, if you have a diagram of my computer, please look in the back of the computer, there is this connection on back that fits my keyboard. Would that work?
    nevermind, looked at the end piece on the keyboard wrong. It doesnt have that connection. Sorry.
    is there nothing else I can do to try to fix the hard drive? Can I just load windows from the optical drive and somehow do something from there, maybe load windows from optical and then after it loads, insert the hard drive back in and hopefully I can get into it without windows shutting down on me? Or anything?
    I tried the f2, and f12 but no hope. I do appreciate your help. Thanks so much.
    What do you mean external hard drive? What does one of those look like?
    I am not sure. I have tried everything. I really needed this computer fixed. Thanks for helping.
    hey could I put the installation on a thumb drive and try booting off it?
    I am in Alabama.
    I actually know someone but, they wont be back in town til Tuesday, and their cell is turned on right now. I just couldnt reboot off the optical drive and and reinstall windows from my thumb drive and then shut the computer down and stick the hard drive back on?
    I am going to try that. I will let you know what happens. Be back in a few!
    Ok, so I was trying something, so i pulled the hard drive out and had the thumb drive in, and when the thumb drive was loading windows files, I put the hard drive back in and suddenly the hard drive was located, so right now I am trying to install windows back on it. I will let you know what happens. Be back in a few.
    So far it is loading Windows, its installing it now. It had to formatt the hard drive first and now its installing Windows. I think this might work. Will give you a final decision when it installs.
    ok so it installed but my screen resolution is terrible. It is set on 640 by 480 pixels and it wont move up, and my quality is on lowest (4bit) and when I click the drop down button that is all that is displays. How can I fix this?
    President:
  • Dell Master
  • 1,314 Answers
1. The reason it says "error loading operating system" is because kill disk wiped the operating system from off your computer.
2. Now that you have the installation disk, you need to tell the computer to boot from it. For Dells, usually press F12 when the Dell logo appears, and it should bring up a boot menu. Select the optical drive and it should boot. If you do not see a boot menu, go into your computer's BIOS and tell it to look at the optical drive first when booting, then it will boot from the disk.
Posted on Jun 28, 2009
  • 16 more comments
  • Kevin Shafer
    Kevin Shafer Jun 28, 2009
    So why rate as inappropriate? At least a thanks for trying, or wait until I can respond. This is why people don't like to help other people because they give bad ratings. Please change the rating and I will explore the other avenues with you. In inappropriate rating would be me telling you to throw the thing out.
  • Kevin Shafer
    ESPECIALLY since you didn't provide that other information in your original post.
  • Kevin Shafer
    Thank you.
    Now, a bit of troubleshooting.
    Does your keyboard light up at all? Is it a wired or wireless keyboard?
  • Kevin Shafer
    My apologies; I failed to see it was a laptop.
    Okay, First unplug the laptop and remove the battery for 10 minutes. Put the battery back in and plug it back in. Press the power button and as soon as it lights up tap on the F12 key. Keep tapping all the way until the boot menu displays or it goes to the operating system not found message and report back to me. Thanks.
  • Kevin Shafer
    1. Do you have an external USB keyboard available? If so, plug it into an available USB port, see if the keyboard's lights flash when you turn it on and try using the external keyboard to pull up the BIOS or the boot menu. (trying to see why your keyboard isn't working, or if that is the issue)
    2. Try removing the hard drive and, with the hard drive removed, boot the system to see if it will see the optical drive. (trying to see if the operating system not found error is from the hard drive or if there is another problem).
  • Kevin Shafer
    Okay, I just pulled your manual up so I can see exactly which keys. On your computer, the F2 key is the key to use to get into system setup. Have you tried that?
  • Kevin Shafer
    Here is a picture on how to remove your hard drive. Remove it, and with it still out, turn on the computer and see if it will boot off the CD. Then, after you turn it back off again, put it back in and report back.
  • Kevin Shafer
    Okay so now we have verified that indeed the optical drive and the installation disc are working. We just can't get it to boot into BIOS or the boot menu to change the bootup sequence. Have you tried accessing BIOS (F2) again with the hard drive back in? As soon as you press the power button to turn it on press F2 repeatedly, keep tapping it. Also, if it still doesn't work, try it with the hard drive removed and the installation disc removed.
  • Kevin Shafer
    It's gonna be one of those lol. It appears that the main problem is the computer is not recognizing the keyboard commands when you first turn it on. Just a few questions:
    1. Are you pressing the F2 key repeatedly from the moment you turn it on until it gives the OS not found screen? I don't mean holding it down, but tapping it dozens of times until the message comes up?
    2.....hmmm....okay I lied only one question :c) I feel however we could solve this if we had another keyboard connected....the keyboard you are using right now, is it a USB keyboard perchance?
  • Kevin Shafer
    Yeah, that won't work on your laptop because it doesn't have the port (and I was hoping it did, I looked :c) And question #1 about pressing repeatedly and holding it down? (Sorry to be repetitive but I couldn't ascertain whether or not I was being understood or not or if you had done it repeatedly or just held it down).
    BRB
  • Kevin Shafer
    Hmmmmm.....it appears I've exhausted all I can do to help at this point. For some reason the computer isn't recognizing the keyboard during the stage that it is looking for a command. And, just to be sure, you are starting to tap it right as soon as you power it on? Try it several times in a row....and, also try alternating between F2 and F12....So, power on, F2, F12, F2, F12, etc...
  • Kevin Shafer
    The hard drive is erased. You should, theoretically, be able to boot off the system disk and tell it to reinstall on the hard drive; it will reformat it. But we, for some odd reason, can't tell the computer to boot of the cd drive. We know the cd drive works, and the installation cd works, and it will boot automatically from it. You can't add the hard drive after you've turned on the computer; the computer wouldn't recognize it for one and for two it could damage the motherboard. You could convert the hard drive to an external device using an enclosure and do it that way but I doubt you would have one.
  • Kevin Shafer
    Basically, it converts your current hard drive to an external so you can plug it into USB. First, you would remove your hard drive, then remove the drive from the caddy that it is in. Also, there may be a connector on the end of your drive that would need to be removed. Then you get an enclosure like this one, attach your hard drive to it, then plug it into USB. But even if we did that, it doesn't solve the issue as to why we can't access the boot menu or the BIOS and what role killdisk had in that.
  • Kevin Shafer
    Though that is possible and certainly worth trying, the problem is the computer checks the hard drive first and when it finds no operating system it stops....which is still perplexing because once it doesn't find one it should go to the next one; kill disk may have wiped the information but it didn't clear the master boot record to show the drive as unformatted. Where are you located?
  • Kevin Shafer
    Okay well that's too far for my business :c) If it's really important to get it taken care of, I would hire a professional....NOT GEEK SQUAD.
    Actually, I can hire a tech to come out there and check it out. I'm afraid I can't think of anything else to get your computer to boot of the optical drive.
  • Kevin Shafer
    Now you could probably take the hard drive out, put your thumb drive in, boot the installation disc and install windows on your thumb drive (should be at least a 4 GB for this as windows will take nearly 2 GB. Then you could run windows off the thumb drive until your friend gets back in town....putting the hard drive in will just stop the boot process again.
  • Kevin Shafer
    Well I'm glad it seems to be working for you....odd though as it seems lol.
  • Kevin Shafer
    Now you need to go to Dell's website and download the drivers for your computer. Enter in your service tag number and it will take you to your computer's drivers. That one is the video driver. Also check in your control panel for other drivers like your sound and ethernet (Lan) drivers. You may have to download them onto your flash drive and move them over manually until you get your Lan drivers transferred over.
How do I uninstall XP Professional and install Windows 7
If you have a Windows 7 installation disk, just put the disk in your drive and follow the instructions......it will remove your XP and install a fresh Windows 7
Oct 21, 2014 | Computers & Internet
Tip
How to delete Microsoft Windows, how to remove Windows
In this tech article I will go over how to remove Microsoft Windows or revert to a previous version of Windows. Why would you want to delete Windows? You may want to remove Windows because you do not like that version you have installed, or maybe you want a different operating system like Linux.
In my method I will not focus on data backup and recovery. If you wish to backup your data, you can do so. After installation of your operating system you can restore the data from backup.
Install fresh operating system
This method is the easiest and I would say least problematic. This will format(wipe) your hard drive and install a clean operating system. No files will be saved or transferred in this method. So be sure to backup any important data you wish to save as it will be deleted during this method.
1)You will need the operating system media. The operating system you wish to install can be on a DVD or USB flash drive for example.
2)Insert the media and reboot the computer.
3)As the computer is booting up, you will see some options come up during the boot process(very briefly). One of these options will be for your BIOS. It may say press f11 for bios, or DEL for settings. What we want to do is go into the computer BIOS and change the boot order.
4) Once in the BIOS, change your boot order so the operating system media is booted first. For example, if you have your new operating system on a USB flash drive, then you want to make sure the USB flash drive is first in the boot order list.
5)Once you make the boot order changes, exit out of BIOS saving your settings. When your computer reboots again it will boot to the media you selected.
6)Depending on what operating system you had installed before, you may get different options. You may get options to perform a recovery and or to just do a fresh install. We want to make sure you do a fresh install. This will format(wipe) the hard drive and install the operating system you wish to use. The hard drive will be formatted and the operating system installed. Once installed, you will go over settings basic computer settings like language, time, computer name and internet connectivity. This varies depending on the operating system you are using. Be sure to follow the on screen prompts.
If you installed Windows 7 over an older version of Windows
In this method you can revert Windows 7 to a previous version of Windows. The Windows 7 installation will have created a Windows.old folder that contains your previous operating system and personal files. This Windows.old folder is in the root of the Windows partition. Reverting does not keep any current files or settings so beware. Your computer will be reverted to its previous state before Windows 7 was installed.
The following tech article from Microsoft will go over the process to revert Windows 7 to a previous version of Windows that was installed.
http://support.microsoft.com/kb/971760
The following tech article from Microsoft will go over how to do this process with Windows XP.
http://support.microsoft.com/kb/303661
Wipe hard drive securely
If you want to truly erase data you will need to use software utilities to do this. Deleting data on your computer or reformatting your hard drive will not completely erase the data. There are numerous software programs out there you can use, free and costly.
A free tool you can use to erase your hard drive is KillDisk. You can click the link below to visit the site and download the software.
http://www.killdisk.com/downloadfree.htm
I hope my article was informative. Be sure to check out my other Tips and Tricks by clicking on my profile name and then clicking on "Tips" at the top left of my profile.
Regards
G33k
Keywords
How to remove windows, how to delete windows, delete windows, remove windows, how to remove Microsoft Windows, How to delete Microsoft Windows, how to remove Windows 7, how to delete Windows 7, how to revert Windows, how to install new operating system, how to delete operating system
on Jun 15, 2011 | Computers & Internet
How to completely erase the hd
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
or you could just reinstall another operating system this will automatically delete the old wrong one you installed.
Hope this helps.
Jan 02, 2013 | Western Digital WD Scorpio Blue WD5000BEVT...
Unistall windows 8 pro
You have to install another operating system
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
or
Formatting a hard drive to erase its contents does not mean the files are necessarily gone forever. Using data-recovery software, someone still could retrieve sensitive data and files from your hard drive even after you've formatted it. Instead of simply formatting your hard drive, use disc-cleaning software to permanently erase its contents. Disc-cleaning programs work by repeatedly overwriting the contents of a hard drive with random data patterns, making it virtually impossible to recover the original files. Download and install the freeware program Active@ KillDisk (see Below). http://www.killdisk.com/downloadfree.htm Click the Windows "Start" button and select KillDisk from the "All Programs" list. Click the check box next to the hard drive you want to erase in the "System Local Disks" menu. Press the "Kill" button. Select the erasing method you want to use from the "Erase Method" drop-down menu. Active@ recommends using the "US DoD 5220.22-M" method. Click "Start" to begin erasing the hard drive. Download and install the freeware program Hard Drive Eraser (see Below). http://www.harddriveeraser.org/ Click the Windows "Start" button and select Hard Drive Eraser from the "All Programs" list. Check the radio button next to the hard drive you want to erase under "Select Drive to Erase." Select the erasing method you want to use from the "Shredding Scheme" drop-down menu. The developers of Hard Drive Eraser recommend "DoD 5220-22 M" Press the "Start" button to begin erasing the hard drive. Download and install Iolo DriverScrubber (see Below). Click the "Windows" Start button, "All http://www.iolo.com/ds/3/ Programs" and then the DriverScrubber program icon. Click "Wipe all contents of a drive," and then click "3.5-Inch Floppy Disk." Insert a blank floppy disk and click "Next." Restart your computer with the floppy disk still inserted. Your computer will boot directly to DriveScrubber. Press the down arrow on your keyboard to highlight the hard drive you want to format in the "Available Physical Drives" menu. Press the space bar to select the hard drive. Press "Enter" to continue. Press the down arrow to highlight "Seven Overwrites" in the "Available Data Wiping Methods" menu, and then press the space bar to select it. Press "Enter" to continue. Press "CTRL," "ALT," "Shift" and "W" at the same time to wipe the hard drive. Hope this helps.
b>
Dec 30, 2012 | Dell Computers & Internet
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
I had vista and was installing windows 7 and got to the network part of the install and the system went to resart and it went to a black screen with a fashing curser and now i can not access anything on my...
guess u were trying to install Win7 over Vista...it does not work that way....Win7 need to be a clean install...that is...it must be installed in a new partition after doing a full low level format....so you will have dual boot at start up...and u chose what u want vista or Win7 to work with for that specific session....
Dual boot helps in many ways...
1 - it helps file management better
2 - it helps to boot from one OS in case the other gives trouble
3 - virus attack are removed from either OS
etc etc
the best way to getback you system is to
1 download KILLDISK (DOS) utility program, get the DOS version
2 copy it on to a CD
3 get hold of a Win98 CD (bootable)
4 boot from Win98 cd, dont chose to install Win98,
5 press ESC and let Win98 quit installing, it will lead to a drive letter of you CDROM (say D or E as the case may be)
6 insert the CD that has the KILLDISK DOS utility
7 Run the program by typing KILLDISK at the CD drive letter prompt.
8 Read all the options available there...and kill the drive in which you had VistaOS/Win7 (C)...this will make all you C: drive sectors to "0"
i.e. it will wipe your C: drive clean and u can start with a clean slate....
if u r not concerned with the data in you disk...wipe all drives and disks in the PC....a 20GB disk will take aprox 1 hr to finish
for all this u must have the BIOS enabled to boot from CDROM drive...
once killdisk has finished doing the wiping process....
insert the Vista or Xp cd and install either...in the partition option make 3 or more partitions....C, D, E of at least 30 GB min for each...as Win7 will take aprox 18 GB....
in C: drive install Vista or XP as the case may be.....
once done....let the system boot and let it load Vista or XP
once in Desktop you can insert the Win7 cd and install it on the D or E: drive....the CDROM drive letter will change accordingly....when you make the partition....so be carefull to
let me know....
reg
Jul 17, 2010 | Computers & Internet
I want to reboot my compaq presario 2100 to its original setting like when u first buy it.
ok...
u need the PC to be in factory setting....i guess so
u will need either of this....
Killdisk or Wipedisk
i have not used Wipedisk but i guess it's same as Killdisk...
Killdisk is a DOS utility that will wipe ur disk(make all ur Hardisk sectors 0000000.....)
but before using it ensure u bakup ur data from your PC....Killdisk takes about 30 mins to do 10GB of space so u can mutiply....if u have 100GM it will take 3 hrs to complete....the trial version of killdisk does only 1 pass(that's more than enough to wipe the disk to the original state)
you can always do the process twice to double sure that all sectors are cleared of corrupt data.
then u can load the OS from the OS disk
to use killdisk u will need to copy the program in a CD and also make a boot disk CD to boot the PC and get the drive letter of you CD/DVD rom drive at DOS prompt.
i suggest u make a boot disk before you wipe you PC
once u have booted from the boot disk, load the cd with the killdisk program and wipe your PC Hardisk
Dec 09, 2009 | Office Equipment & Supplies
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Hard drive not working properly
What is the original OS? If it's XP you can't install 98 over the top of it without formatting it to FAT32 first.
Nov 07, 2007 | Gateway Essential 500 PC Desktop
Dell Inspiron 1100 Notebook Logo
1,280 people viewed this question
Alun Cox
