Question about Toshiba Satellite Pro 4600 Notebook
Toshiba Satellite Pro 4600 Says D Drive is Out Of Memory
Error says D: is low on memory but can not find drive when opening computer?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Is the D drive your second hard drive? Have you ever done a Diskcleanup and a Defrag?
    Novelist:
    Champion:
  • 226 Answers
One can only venture a guess on this one: your hard drive is partitioned into C: and D:. Physically, there's only one drive, but it might have been split into 2 separate partitions. I'd go from there.
Posted on Mar 12, 2010
Low disk space. Low memory. How to stop this error?
This behavior can occur if the Outbox.dbx file is corrupted.
To resolve this behavior, rename the Outbox.dbx file:
- Click Start, point to Find, and then click Files or Folders.
- In the Named box, type Outbox.dbx.
- In the Look in box, click your primary hard disk (usually drive C), and then click Find Now.
- Right-click the Outbox.dbx file that appears, and then click Rename.
- Type Outbox.old, and then click OK.
- Restart Outlook Express to rebuild the Outbox.dbx file, and then send the message.
Also you can find 100% solution www.outlookexpress.repair
Aug 30, 2017 | The Computers & Internet
Too low memory problems
Upgrade the memory and the problem will be solved. Please let me know your laptop's model. You can use other computer to check the replacement memory here: http://www.crucial.com
Mar 10, 2014 | Computers & Internet
Low memory error
Read know a little about PC partition low memory problem? Don't worry! Here is a video tutorial that can teach you how to extend your C drive space step by step:
https://www.youtube.com/watch?v=6jCeT7CbsKk
Also remember to save your partition data well in advance.
Oct 09, 2013 | Dell XPS Computers & Internet
Dell studio low memory
Low memory problems could be low virtual (hard disk) memory.
Hard disk maintenance will free up hard disk memory space.
Hard disk maintenance should be carried once a month to make your computer run efficiently.
This removes redundant and temporary files, recovers disk space and speed up hard disk access.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Jan 04, 2013 | Dell Computers & Internet
LOW MEMORY
Hi Yeyek0905,
Good day!
I understand that your computer is running on Low memory.
If you have budget, it would be best to upgrade your RAM but then you may try the following solutions below:
For Low Virtual memory on Windows XP:
1. Click Start, then open the Control Panel.
2. Select Performance and Maintenance, and then click System.
3. Click the Advanced tab.
4. Under Performance, choose Settings.
5. Click the Advanced tab.
6. Under Virtual memory, click Change.
7. Under Drive [Volume Label], click the drive that contains the paging file (virtual memory) settings that you want to change. In almost every case, this will be your C: drive.
8. Click to select the "System managed size" option, then click Set.
9. Click OK three times and restart your computer
For Low Virtual memory on Windows Vista and windows 7:
1. Click Start, then open the Control Panel then select on Systems.
2. Click on advanced tab and select on settings for the performance option.
2. Select o the advanced tab then check on Virtual Memory(Change).
Uncheck the "Automatically manage paging file size", and select 'Custom Size'.
Increased the size based on the Recommended levels+200mb
You may also do the following to free up some space:
1. Delete Temporary files
a. Click on start and type in %temp% on the run option.
b. Delete all your temporary files.
2. Do a disk clean up.
a. Click on Start
b. Accessories
c. System tools
d. Select on disk clean up.
I hope this helps.
Best regards,
Jheycie
Jan 02, 2011 | Computers & Internet
System says low on virtual memory even after I zero & format the hard drive with new operating installed?
this is virus instaled on computer bios or defective memory boards.
1st replace memory, and check-it.
2nd find a original bios on IBM website, and flash-it.
Nov 22, 2009 | IBM NetVista PC Desktop
Computer says no memory left but there is. my computer keeps saying your computer is running low on memory no matter what i delete or change, also i seem to have two hard drives but it only uses one of...
I'm assuming that your operating system is XP and it's running low on Virtual memory.
Right click on My Computer and select properties from the sub menu. A System properties window will open so click on the Advanced tab. On the performance section click on the settings button. A performance window will open. In the Virtual Memory section click on change. Select System Manged Size and then click on Set. You may get a warning message so just select yes or OK to everything. Click apply and OK in the System Properties window and then restart your computer.
You should not get any low memory messages from now on.
Regards.
Sep 29, 2009 | Acer Aspire 3690-2196 Notebook
Memory low for unknown reason
when you reformated the drive you must not have deleted all partitions , otherwise you would have all the disc space minus the operating system , so check and make sure all partitions made were deleted and the full size of the disc is available for the new installation
Dec 11, 2008 | HP Pavilion dv6000z Notebook
N70 mmc corrupted and can't be formated
in ur phone go to Tools ,memory,options and Format memory card.....
It will work......!!!!!!
Oct 01, 2008 | Nokia N70 Cellular Phone
My laptop keeps coming up with low memory!
Low memory usually refers to the RAM. Low space refers to the Hard Drive. You might have too many applications/programs running at the same time on your laptop. Or have an application or program that is using up too much memory. Viruses/Spyware sometimes do this to put your computer in a state that is not usable.
So what you can do is add more RAM. And check your "Task Manager" for applications and/or programs that is using too much RAM. Look under the column "Mem Usage"
Aug 17, 2008 | Toshiba Satellite A70-S249 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
