Question about Samsung HL-S5087W DLP TV
We have 2 problems....dark screen/bright light on right side
We have a Samsung HL-S5087W 56" DLP - we replaced the lamp because we were having problems watching the TV during the day - it was dark and hard to see, unfortunately the new lamp hasn't helped. Secondly, prior to replacing the lamp we started noticing a pie shaped bright line running down the right side, it starts about 1 inch wide at the top right corner and disappears about 3/4 of the way down. It almost looks to me as if this bright line should be what the entire screen looks like, then I could see it during the day! The line is still there after replacing the lamp. Any assistance would be great, we love our TV !
    Top Expert:
  • Samsung Master
  • 74,999 Answers
Replace the light engine. If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Apr 11, 2017
SOURCE: Dark shadow
I found this forum with others who had the same problem. You should check it out:
Posted on Oct 30, 2007
  • 1694 Answers
SOURCE: Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Posted on Nov 07, 2007
SOURCE: Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Posted on Feb 08, 2008
  • 208 Answers
SOURCE: Dlp problem
The unit has a defective light tunnel contained within the light engine. This part is not easily replaced and you will a qualified tech to replace it. Many service centers condemn the light engine at a much hight cost. Do not buy or let someone tell you the light engine must be replaced. This repair requires only the light tunnel.
Posted on Feb 10, 2008
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
I went through the same exact thing. I had to replace the DMD board. No problem after that.
Feb 26, 2015 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
I have a Samsung 42" DLP. During the daytime I can hardly see the people and definition on the screen. It is all very dark. Nightime is better.
check your video settings there are 3 or 4 usually that all have various levels of brightness, it may be set to one of thelower ones. or you can go into tv menu and try kicking up the brightness. if no luck the lamp may be failing if not recently replaced they begin to make screen darker before they fail.
Jan 23, 2010 | Samsung DLP HL-P5663W 56" TV
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP Dark Picture
try to reset the tv setting to its manufacturer settings and see if it fix the problem
Feb 01, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R5056W 56" TV Problem
How old is this TV?
I think its time to replace Lamp.
Oct 03, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-S5087W 56" Confused...
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
May 08, 2008 | Samsung DLP HL-P5663W 56" TV
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
Jan 16, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5087W DLP TV Logo
368 people viewed this question
Jerry Greenberg
Jerry Greenberg
