Question about Sony KDSR50XBR1 50" Projection HDTV
TV loses picture/sound after 5 minutes then comes back. Repeat
The TV starts up fine. After 5 minutes, sound and picture disappear. Standby light blinks continuously for 1-2 minutes, then sound and picture/sound return. Standby light steady. Symptoms repeat randomly every 5-7 minutes.
Checked all the connections and performed a reset according to the manual - no help.
Set is 3 years old, no previous problems.
HELP!
    Top Expert:
  • Sony Master
  • 75,774 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Sep 03, 2017
  • 1894 Answers
SOURCE: KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
Posted on Dec 28, 2007
racer7x
  • 42 Answers
SOURCE: Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Posted on Feb 10, 2009
video-tek
  • 150 Answers
SOURCE: Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
  • 73 Answers
SOURCE: Picture & sound go off for 1-2 minutes, then return.
If the green light starts flashing after losing pix and audio and then becomes solid and pix and sound return.I would suspect lamp.
Posted on Jul 14, 2009
SOURCE: picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Posted on Nov 17, 2009
Dec 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony Plasma TV
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 12, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Picture disappearance & tv turns off
It sure sounds like you have a classic case of bad solder joints. Resolder all the connections on all boards.
May 31, 2006 | Toshiba 36A43 36" TV
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
