Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Apex 43 inch tv
I am inquiring for an apex 43 inch tv that someone posted in the ads where i live and they said it has a small white line going through the middle of the screen. They said that someone told them that they need a convergance for it. What is this convergance and how do i fix it or get it?
Re: apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Posted on Dec 14, 2007
0 characters
3 Points
Samsung Tantus projection TV 40 inches. the problem is that when it has worked for 5 minutes the text and picture is having a trace line that looks like a convergence problem in conventional CRT tv. any...
U have the early warning problems of the convergence problems.Do the manual or auto convergence adjustment until,u can't do it anymore.Replaced all the parts,that make the convergence board to work.
Jun 22, 2010 | Apex Digital GB4308 43" Rear Projection...
Apex gb4308 43 inch projection tv
This is not my main field of expertise, in any case here is the link for a solution to same problem and same model. According to expert the problem is related to vertical chip fault.
hope it may help you
Feb 18, 2008 | Apex Digital GB4308 43" Rear Projection...
Hdmi cable location???
Click HERE to see HDMI Jack image, if it is there at back of TV then OK and if do not, then TV has No HDMI facility.
Apr 28, 2009 | Apex Digital GB43HD09 43" Rear Projection...
3d picture
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Hope the blog helps you.
Dec 28, 2008 | Sony KP-43HT20 43" Rear Projection...
Problem with tv APEX DIGITAL GB4308
it sounds like your lenes need cleaned and alined
Dec 08, 2008 | Apex Digital GB4308 43" Rear Projection...
Apex projecter
Buy a new one! Mine won't even make a noise.
Mar 15, 2008 | Apex Digital GB4308 43" Rear Projection...
Help with my tv
I don't know what you mean by "good". I've worked on this set several times for different problems. What do you need ?
Dec 02, 2007 | Apex Digital GB4308 43" Rear Projection...
Tv screen scratches
If this is the clear smooth screen, yes you can go to your local glass & paint store & have a new protective screen cut for that size. If this is the screen with thin lines etched in it from top to bottom..vertically is the Lenticular lens & no there is no way to repair, you must replace, with new or used. Go to ebay under projection tv parts see if you can locate someone having your size for sale & bid on it or email them to outright purchase it.
Jul 21, 2007 | Apex Digital GB43HD09 43" Rear Projection...
Apex model#GB4308
If you mean a horizontal line going left to right across the center of the screen and it's intermittent then a tech should be able to fix that one on a service call fairly easy... The vertical IC in that unit, IC N301, is a TDA8351 and it most likely has some poor solder connections due to heat stress - we call ring cracked - thus the problem sometimes corrects itself temporarily. While he's coming out anyway ask him ahead of time to bring the following: Two resistors 1.0 ohm 2 watt and a cap 3300 microferet 25 volts and his DMM & ESR meter. Ask him to ESR test C863 this is a high failure cap and test R370 & R371 in the supply for change in value. Shouldn't be too much to repair - and simply ask ahead of time what they charge for a service call, and if they think they can correct such a problem (ring cracks on the solder connections of your vertical IC) on-site. If you're not too sure where to begin your research for a qualified shop try NESDA at: Good Luck Bill
Jun 13, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex gb4308 multi colored horizontal bow in middle or screen.
This is not an "STK" problem. Your problem is VERTICAL. You need to check your vertical chip for damage CN301 and check around it for any bad parts or loose connections. I've seen loose connections on the chip itself cause it to self-destruct.
Apr 11, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
120 people viewed this question
Top Apex Digital Projection Televisions Experts
Jaime Hernandez
Sudeep Chatterjee
Sudeep Chatterjee
Dave Naylor
Dave Naylor
Are you an Apex Digital Projection Television Expert? Answer questions, earn points and help others
