Had an E25 error yesterday and found the impeller on the pump jammed. Cleared it an the machine worked perfectly for 2 loads. Water is getting in and the pump is removing the water. 10 minutes in the machine stops and the E25 message appears. I am out of ideas. Anybody????
SOURCE: I have had an
Hi Steve E24 error normally indicates failure to drain, the first
thing to check is that the water is actually being supplied to the appliance
and is turned on. If it is then check the water inlet valve, if the valve tests
fines then clean the drain pump assembly completely as that might be clogged
causing this issue. Hope this helps...please post back for further assistance. Daniel
