- Machine off - Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode. - press 80 - press the “mono start” button several times until you see “purge: xxxx” - press “2783” in order to reset the purge counter. You will see: “purge:0000” - press the "stop" button. - press “99” to exit the maintenance mode.
scan not working mfc 5840cn. have tried using software disc and says wrong volume?? think this is a...
(More)
scan not working mfc 5840cn. have tried using software disc and says wrong volume?? think this is a software issue
printer is in lan environment. and is now giving printer offline when trying to print. cables are...
(More)
printer is in lan environment. and is now giving printer offline when trying to print. cables are connected correctly and printer is ON.
message says ''Ink empty cyan open cover'' I have removed cyan and it is full I have replaced and...
(More)
message says ''Ink empty cyan open cover'' I have removed cyan and it is full I have replaced and repeated this several times I cannot turn off printer I cannot activate INK
