Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
I have the 15' X 42'intex metal frame. Pool and
I have the 15' X 42'intex metal frame. Pool and skimmer function fine, but need to vaccum the floor. How do i connect the vaccum to the aluminum pole and the skimmer hose????
  • 297 Answers
Watch the video at itex.com
Posted on Jul 12, 2009
  • mark Gianotto Jul 12, 2009
    ooooooooooooooooooooooop's Intex :-) Also make sure that if you do not use the pre filter bag set up and go directly to the suction source you should, when you are done vaccuming disconect the hose that goes to the pump you will most likely have hair build up and debris that will slow down the suction. Also rinse your cartridge since you have the plungers set
I disconnect the skimmer from the outlet on the side of the pool and directly attach the vacuum hose to that side outlet. It doesn't have to fit exactly tightly onto the outlet as the suction from the pump will hold it slightly. The hook that holds the skimmer to the side of the pool is somewhat fragile and can easily be broken if you constantly attach and disconnect the vacuum hose from it. Right now my hook is broken and also the vacumm debris bag has a hole in it and I am finding both of these items are very hard to find to replace.
Posted on Jul 08, 2009
  • 93 Answers
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Posted on Jun 30, 2009
WWas working just fine then hooked up vaccum and cleaned pool now the skimmer does not have any suction-- water blows out other side just fine and I have gotten all air out of lines--- any ideas
Depending on how much you vacuumed, your filter may just need to be cleaned. The filter on these units are not very big, so they can get dirty fast. Make sure it is cleaned out. Make sure skimmer basket is not clogged up, and make sure none of the flexible hoses are crimped. Also make sure there isn't anything stuck in the impeller. A stick, twig, or piece of toy, etc, can get stuck and cause low flow. Check for leaks between the suction side of the pump and the pool skimmer. One more think you might want to check is for leaks on the suction side while equipment is off. a leak here will let air into system and effect flow.
Sep 24, 2010 | Intex Krystal Clear Model 635 Pool Filter...
How low do you take the water when closing
Down below the wall fittings, and the skimmer so you can drain the lines. Also be sure you remove the drain plugs from the pump and filter.
Sep 05, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Filter assembly Intex 15X48
The lower hole is for suction and the higher hole is for return.
The Pool Tech
Jul 07, 2010 | Intex "" Metal Frame Pool Set (56998e)...
I've lost the instructions to our skimmer or vacuum to the pool. How do I set it up or get an electronic version to show me how? Thank you.
I have lost the instructions to our vacuum to the pool. Do you have copies of manual's online to view. If not I need an electronic version to show me how.
Jul 02, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Skimmer and Vacuum set-up question
Here is a link to Intex website for the manuals and videos. Intex Pool
Jun 25, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Where does the skimmer sit on an intex metal frame pool
i have mine sitting about a foot to the right of the intake on the pool, that way it keeps a clear line from the skimmer to the intake to the pump/filter to the outlet
May 30, 2010 | Intex "" Metal Frame Pool Set (56998e)...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
1,000 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
