Question about Brother MFC 420CN All-In-One InkJet Printer
My printer will not print and there is an mn1 on the printer brothers mfc-240c
SOURCE:
SOURCE: printer keeps turning off,,,error message MN1 in lcd
I realise this is an old question but I recently had a similar issue with our MFC-5860CN not receiving faxes and displaying the "Mn1" code. As it turns out "Mn1" means the machine is set to manual receive and was therefore not automatically receiving faxes. You will need to locate the "Receive Mode" option in the menu and change it to "Fax Only" or "Fax / Tel". Unfortunately I dont know what could have caused the turning off and on that the OP mentioned. I'm a little late to the party but I hope this info can help someone else!
Posted on Jul 07, 2008
SOURCE: Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Posted on Jan 29, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
  • 270 Answers
SOURCE: paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Posted on Dec 12, 2009
  • 904 Answers
SOURCE: Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
Posted on Jun 04, 2010
How can I set my MFC-240C printer to print from my computer
switch on the printer
1. install driver for mfc-240c
2. go to control panel in your computer
step to control panel
select START then control panel
3. select printer mfc-240c right click on it and then click on click on <Set as Default Printer>
4. right click again on it the select <properties> then select "print test page"
test page will printout on printer
5. now you can use mfc-240c as printer
Aug 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
Can my brothers mfc 240c printer be used to print from more than 1 computer in my house wirelessly? how do I set this up?
The MFC-240C does not have a wireless interface, so you can't connect wirelessly directly to it. What you would have to do is set up a print server, which can be a standalone device or can be one of your computers, and then the other computers would print through that one connected computer.
Jun 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
The control center cannot find my mfc-240c, although I can print from my computer to the mfc-240c.
Maybe you have incorect version of Brother control center or anything at installation you do wrong?
Jun 21, 2010 | Brother MFC 240C All-In-One InkJet Printer
Need to replace drum kit in a 240c brothers printer
drum unit is part of laser printer and MFC-240C is inkjet printer
parts that you might replace is print head, ink cartridges, ink absorber box
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC 240C won't Print
have you tried to unplug the machine for twenty minutes then plug the machine back so that it will reboot?
Jan 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have windows vista and mybrother MFC-240C won't print, Says can't find printer?
first unplug ur usb cable from ur mfc-240c than deinstall all drivers of your printer
than reboot your system
than go here:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=mfc240c_all&lang=all&src=DOWNLOAD
click on your country flag and download the latest drivers for ur mfc-240c
install it
than when asked for ut plug in your usb cable from ur mfc-240c
the computer wil find your mfc-240c now whend asked for reboot than reboot
Dec 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 420CN All-In-One InkJet Printer Logo
186 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
