Question about Vizio P2 42 in. HD-Ready Plasma Television
TV WILL NOT TURN ON BUT VIZIO LIGHT IS ON
PROBLEM IS SIMILAR POWER SHUT OFF BY ITSELF AND WILL NOT TURN BACK ON. TV IS ONLY ABOUT 7 MONTHS OLD. VIZIO LIGHT IS ON BUT PICTURE WILL NOT TURN ON, DOES THIS STILL SOUND LIKE POWER BOARD ISSUE AND IF SO IS THERE A 12 MONTH MANUFACTURE WARRANTY? I PURCHASED THE TV AT WALL MART BUT DID NOT BUY THE SERVICE PLAN .
    President:
  • 1,077 Answers
The Service Plan from Walmart is an "extended plan" on top of the manufacture warranty. Your Tv is still under warranty from the manufacture.
Here's a link to get the info you need to get started on a warranty claim:
http://www.vizio.com/support.aspx?id=1588
Posted on Jun 28, 2009
Power Light stays Yellow
sounds like you have a power issue, or maybe the power switch is faulty. check that.
Jul 17, 2008 | Vizio L32 32 in. LCD HDTV
My vizio 32 inch LCD tv shut itself off after being on for 5 hours tv was not hot I finally got it to turn back on after 15 minutes since then it has been fine what could have caused this
Set may have like a car with a check engine light have detected something and shut down as protection-----monitor it and if it gets worse or repeats consider having a shop examine it.
I would suspect issue is or was on power supply board.
May 16, 2012 | Vizio Televison & Video
The audio and picture on my vizio vt470m are scrambling and then the whole tv locks up and turns itself off. tried fixing with the "unplug everything, hold power button for 30 sec, and turn back on...
You could have Bad Capacitors on the Power supply board they will be vented or swollow on Top
1000uf 16v 2200uf 10v 3300uf 10v.
PTS they rebuilt boards 1-800-844-7871
May 30, 2011 | Vizio VT470M 47 in. TV
TV was on and shut off by itself. will not turn
Probably power supply, call Vizio for slow service
May 12, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Power
The reason the tv is turning itself off, because most TVs have a "Protection Mode" that turns the unit off when it detects a failed part inside the tv.
The most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
Being that the TV is under a year old, it should be still under manufacture warranty. Last thing you want do is void the warranty by opening up the TV. Here's some info to get you started on the warranty:
If it not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
Nov 24, 2006 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
790 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
