Question about Haier HPAC99ER Air Conditioner
Its obvious that the fan is not working. It comes on once and a while for a brief time then wont turn on again. I can hear the compresser working. How do I fix?
    Scholar:
  • 70 Answers
Replace fan motor more than likely. My be able to run a little oil around shaft. If shaft has side play its done. If it is just stiff oil may free it up.
Posted on Jun 28, 2009
What's your problem?My hd70 stopped working: when i go to turn it on you can hear the fan spin up but where as in the past there is a brief delay and then the bulb lights up, there is now a long pause
It will be worthwhile to test the lamp on another unit or at a test center to confirm as the fault seems to represent a faulty lamp. If this is confirmed then the we can proceed to access the voltage on the lamp , if so the trip is due to low delivery from the power supply section and so it trips on loading of the lamp.
Dec 12, 2011 | Optoma HD70 DLP Projector
When it starts it beeps 3 times and then shuts down
It sounds like it might have overheated, first let it cool down for a little while then and try again. If it starts working again, get compressed air and clean out the PS3, and possibly get an external fan to stop so this doesn't happen again. If the PS3 still does the 3 beeps try putting the PS3 in recovery mode by going to the recovery menu. Which can be done by doing the following.
  • Turn off the PS3
  • Hold the power button down; the system should turn on and turn itself off.
  • Once its turned it self back off press the power button intill you hear to beeps
  • After you hear the beeps let go of the power button
  • You will told to plug your controller in and press the PS button
  • Then the recovery menu will pop up
If the PS3 still doesn't turn on it be dead and need to be replaced. Best of luck!
Jul 18, 2010 | Sony Video Game Consoles & Games
I have a PS3 and it is blinking a red light it beeps three times and then turns off can you help?
It might have overheated, first let it cool down for a day and try again. If it starts working again, get compressed air and clean out the PS3, and possibly get an external fan to stop this problem from occurring again. If the problem pretests, try putting the PS3 in recovery mode by going to the recovery menu. Which can be done by doing the following.
  • Turn off the PS3
If the PS3 still doesn't turn on it might have bit the dust, and you might have to get a new one. Best of luck!
Jul 13, 2010 | Sony Playstation 3 (PS3) Console
Acer 5610 is getting hot and keeps shutting off.
The fan may have gone bad. Turn the laptop on and put your hand on the bottom where the fan vent is. If you can't hear the fan turning or feel air coming out, the fan is probably bad and will need to be replaced. (Hopefully it hasn't caused any hardware damage and once you replace the fan it should work fine.)
If you can hear the fan spinning but can't feel any air coming out, the duct might be blocked or clogged with dirt. Turn the computer off and blow some compressed air into the fan from about a 45 degree angle. If you feel comfortable opening the computer up, remove the screws from the bottom of the case and take the bottom off so you can get to the fan. Clean the fan blades with a dry lint-free cloth, or with a damp cloth and then dry the blades. Put the computer back together and hopefully the fan should spin freely now and blow air out the vent.
Jul 04, 2010 | Acer Aspire 6530-5143 Notebook PC
My laptop(Toshiba Satellite A105 - S2051) wont turn on with or without battery on a/c adapter. Adapter seems to have a charge but when i plug it in and try hitting the power button nothing happens. I do...
hi, this is tricky, as the machine does seem to freeze even before booting. the fan may have become stuck, use some compressed air with the fan inlet (bicycle pump may do) to clean out some dust.
wait some time and switch on again.
observe if the green lamps for harddrive and cd-drive light up.
if no, the computer does not boot up, it may be then that :
the fan is broke and laptop prevents overheat damage by not booting up(buy a new fan and replace it)
or the machine itself is broke
in either way, if the solution i provided did not help, i would recommend to see a technician!
good luck then
Aug 08, 2009 | Toshiba Satellite A105 Notebook
Laptop shuts off, and wont turn back on.
when power off, push compressed air through vent.
If you can reach fan and remove dirt,
Insist on compressed air to clean every vent.
Install temp monitor to check if CPU is getting hot.
Dec 17, 2008 | HP Compaq nc8000 Notebook
The fan on my 1200 watt inverter does not start when turned on.
No. the fan is to remove heat(obviously) If there is a small or no load on the inverter the fan wont come on(no heat to get rid of)..........this is so a lightly loaded inverter wont kill your batteries as fast.If you load it up(power something big or power several things at once) the fan should start after a few minutes
hope this helps.Good Luck!
Dec 13, 2008 | Whistler PI-1200W 1200-Watt Power Inverter...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
SHARP XR-1S won't turn on
OK - I've fixed mine (so it looks) - loads of dust inside unit seemed to caused the problem - vacuuming vents (as the manual prescribes) just shifts all the dust inside around and obviously causes some disruption.. solution - remove 4 screws underneath and lift off top (carefully) remove side panel screws (where Av inputs are) again carefully. Now go around each vent at the front, side and underneath and give areal good blow in each a few times. Plumes of dust and rubbish fly out - keep going until it's all clear. Reassemble and fingers crossed. Mine then started up and didn't turn off - there's a horrible burning smell (dust settling near lamp I presume) which is now fading. Been working 30 mins now with no trouble!
Hope it works for you - will post another update if I have any further problems - no news is good news!
Grahamkida
Dec 22, 2007 | Sharp XR-1S Multimedia Projector
Haier HPAC99ER Air Conditioner Logo
166 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
