Question about Pentair PUREX MINIMAX HEATER; THERMOSTAT, 60 CAPILLARY - 072022
Triton minimax 400 pool heater won't ignite
Power is clearly getting to the heater because the green light comes on. Filter is clean, seems to be getting a good flow of water through it. Gas is on.
  • 1 more comment
  • annahill Jun 29, 2009
    We have a Purex Triton Minimax 400. A spa repairman just left and determined that the water flow unit or valve is bad. It seemed to think there was no water flowing through the heater. Thanks for your time and I hope my post helps others.
  • fixem2 May 11, 2010
    Multiple conditions must be met before main burner fires; model number is important; is it a PowerMax, NT series or just a MiniMax millivolt heater?
  • paulbp_2000
    paulbp_2000 Aug 31, 2012
    i have the same problem. mine is a minimax. it even makes a slight click when you increase the thermostat temperature.
  • 366 Answers
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Posted on Sep 16, 2009
2 Suggested Answers
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
Purex Triton MiniMax Plus 400 power light is not turning on nor is unit. Checked for power going to unit and no fuses appear to be blown. Thoughts on what might be the issue? Thanks, Dan
if you have incoming power, you may have a bad transformer. those systems run on 24-28v. you can check from yellow wire to yellow wire coming off the transformer to see if you have anything coming out. must check wires coming out of the transformer to each other, it won't register if you check each one individually to ground. hope this helps...
Aug 11, 2011 | Pentair Minimax NT Heater
I have a pentair minimax 400dv ,my heater burner comes on for a minute and then,the burner cuts off. The fan keeps running, the burner will ignite again. This will do this several times. Eventually the...
Cleaning the Thermal couple can work at times, however most times you will need to replace it. You may also be having an issue with the ignition control. You are in pretty deep now and it would seem like you are determined to save this heater, I would change them both.
http://www.parts4heating.com/Pool-Heaters-Pentair-MiniMax-NT-400-s/696.htm
Jun 30, 2017 | Pentair Minimax Ch 400,000 Btu Propane...
I turned the gas off to my unit (Minimax 400 w/auto elec ignition), cannot get it to light now.
Making sure the power is off you can try to bleed out the gas line by cracking open a connection near the heater. Let it run till you smell gas. Then tighten it up and let it sit for fifteen or twenty minutes, to be syre the gas has cleared then try it again.
Jan 10, 2010 | Pentair MINIMAX MODULE, IGNITION CONTROL
Minimax 400 heater not operational
what is ok on the water pressure? th heater need from 40 to 60 gpm in order to work properly clean the filter and let me know
Sep 10, 2009 | Pentair Minimax NT Heater
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pentair PUREX MINIMAX HEATER; THERMOSTAT, 60 CAPILLARY - 072022 Logo
2,540 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
