AC not working. Sound but no cold air.
I got this email from a tenant in our condo. The AC is a GE, through the wall model.
The AC unit in our bedroom doesn't seem to be working. When we turn it on, it sounds like it's working, but there's nothing coming out of it, on any of the settings.
Any suggestions?
Beth Day
    Scholar:
  • 70 Answers
Dirty filter and or froze up indoor coil. most likely locked or stuck blower motor.
Posted on Jun 28, 2009
Wall AC Unit blows cold air for a little bit then blows hot air. If I turn it off for a while, it will do the same thing.
When you mansion water in the pan, do you mean the indoor coil pan or the outdoor catch "pan"? I've seen some models have a drain plug that's on the bottom of the outdoor panel or underneath. And that plug should remain installed. It uses that water to cool the copper freon tube that curves along the bottom of the outdoor section. With plug removed it can overheat. Basically it does not drain onto the ground outside, it retains its water. And the air entering side of outdoor coil is clean? May sound like repetition(forgive me). The side you see clearly is the air leaving side. The dual shaft motor has a run capacitor that may be weakening. And the outdoor air that passes thru the outdoor coil may be recirculating out then directly back in to the unit causing it to overheat. Anything blocking airflow outside? 10 mins of runtime then shouting down tells me its overheating. It may even be the electrical circuit. Loose connections can cause high amperage, low voltage issue and cause the ac load to over amp. Over amp=over heat. Hope this helps!
Jun 27, 2015 | LG LWHD1800R Wall/Window Air Conditioner
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
I have a fairly new GE Zoneline heating unit, and live in New England. This past winter, the unit has become VERY noisy, with loud vibrations, crackling noises and a fan that sounds as if it is on its...
This unit only has a warranty for 1 year. Have you followed the use and car instructions? If your looking to get the unit fixed follow the support link below and use the contact number for ge located on the right side of that page:
http://www.geappliances.com/service_and_support/contact/
Thank you,
Lee
Feb 28, 2011 | GE Zoneline AZ38H12DAD Split System Air...
I have 2goodmanGKS9 gas furnaces(propane) installed on 27 Dec 2009. Both units are working. One is in the basement adjacent to the rear outside wall. Lower unit heats about 1200 square feet. Lower...
well lets start with the 2" pvc pipe. that is a combustion air intake it does not put air into the room, i hope. this is a 90% furnace and they should have installed it that way. there should be 2 pipes to the outside the other is combustion gases. the dust problem maybe caused by the air return pulling the air to that room. the bedroom normaly does not get the trafic that the rest of the condo does.so it would not have as much dust.
Feb 10, 2011 | Goodman Heating & Cooling
I just bought a condo, it was built in 2009. When
Fire chaulk is designed just seal and not allow air in by pipes and or wiring to prevent fires from getting air to start and spread.
If you are hearing a constant drip they may have a leaking toilet or faucet just dripping a little causing this. If everything is right sound proofing when installed like cast iron stack between walls to limit noise.
But you may ask them to make sure nothing is dripping .
May 11, 2010 | Plumbing
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
