Question about Kenmore 22642 Top Load Washer
It washes ok but when it gets to rinse cycle it stops and then nothing
  • Kenmore Master
  • 3,361 Answers
Replace the lid switch.
Posted on Jun 27, 2009
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 25, 2015 | Bosch Washing Machines
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Washing machine does not complete wash cycle. Gets to rinse than stops. Does not rinse or release water. When I manually move the dial to spin, nothing happens?
You need to check the pump it sounds like you have something in it .Clean out the pump and the unit will finish the cycle if the pump is not burnt out.
Sep 18, 2011 | Washing Machines
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I just had a Frigidaire front load washer installed today model #GLTF2940FS1 and I am having a problem with the rinse cycle. When the wash cycle is completed and the spin cycle the machine will stop at 26...
hi thanks for the question make sure both water taps to washer are on check that because if the cold water if off it wont go into rinse cycle thanks the appliance doc
Sep 27, 2008 | Frigidaire Washing Machines
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Kenmore 22642 Top Load Washer Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
