I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady,
I would suggest a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84
here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
