Question about Garden
The motor is running while the chain doesn't advance. somebody told me there some plastic sprocket ?? or the other that is worn. I went to my supplier; Building Depot Curacao: they promised they can repair but didn't no spare parts available
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain from the saw. Behind the clutch is the sprocket mounted to the outer component of the clutch. It should be made of steel with relatively unworn teeth. Have someone hold the outer ring of the clutch and try to force the chain past the teeth of the sprocket--it should not be possible with tightly held chain. Use good gloves when trying this one. If sprocket appears to be ok, get some carburetor cleaner and wash out the interior parts in the clutch--it may be highly oiled--not good for necessary friction.Make sure chain is properly adjusted and saw is oiling it properly--a light oil track aroud the periphery of the bar is good.
Posted on Jul 04, 2009
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
Remington Pole Say
check for a roll pin in the gear or shaft that has sheared off
check that the square end of the drive shaft is not rounded off or that the square drive in the gear is in fact locking on the drive shaft and not turning from worn out
Jun 20, 2016 | Remington Electric Pole Saw
Motor runs but chain does not move
Probably the shaft on the sprocket has sheared off.
Knox Knolls Outdoor Power Equipment
Springfield, IL 62704
www.knoxknollsope.com
Oct 14, 2012 | Remington Electric Chain Saw
I have a Troy Built electric chain saw that has ceased to function, The motor runs strongly but the chain will not move. hat do I do?
Does the sprocket drive shaft turn when the sprocket does not? If so, look for broken coupling between the shaft and the sprocket. If the output shaft doesn't turn, then suspect a damaged (probably plastic) gear within the gearbox. Hope this helps!
Jun 02, 2010 | Troy-Bilt Troy Bilt 18" Chain Saw Repl...
Motor runs but chain does not move?
Check the chain drive sprocket to see if it moves when the motor runs. If not, there may be a sheared key between the shaft and sprocket or the teeth on the sprocket are badly worn off. Hope this helps!
Dec 22, 2009 | Garden
My ryobi chainsaw rcs 2040 keeps stopping but motor is still running, chain not moving!
RYOBI----- with the motor running at high revs the chain stops indicates that the sprocket behind the centrifugal clutch is worn out or the centrifugal clutch itself ,or the clutch shoes are worn out the way to tell is to remove the bar and chain and have alook where the chain was conected to the saw, i think you will see the sprocket is buggered and as that is attatched to the clutch drum that will have to be replaced along with clutch springs and shoes, i think you have been running the chain a bit too loose or not running it at realy high revs ,which is what they are designed to do ,cme back to me if you feel the need
Sep 21, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Unit works but chain stops when pressure applyed, what oil goes resevior.
Does the motor continue to run when chain stops? Electric saws usually don't have a clutch, so I would look for badly-worn chain sprocket, or a possible sheared key in the sprocket hub, or a loose mounting nut. Remove the chain and bar, try to turn the sprocket by hand (wear good gloves). There may be some type of overload clutch built into the sprocket.
May 09, 2009 | McCulloch 10" Electric Pole / Chain Saw
Chain does n't rotate
Is the chain brake "on"?, can you pull the chain around the bar?
Is the drive sprocket teeth worn all the way through.
Does the engine high rev or is it loaded when you throtle up?
Jan 31, 2009 | Ryobi Garden
Chain
Yes. It’s likely that the sprockets are worn. Putting a new chain non a worn pair of sprockets will make the chain wear out faster—and replacing the sprockets without replacing the chain will sear out the sprockets. Do them as a set.
Nov 20, 2008 | 2005 Harley Davidson VRSCB V-Rod
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
